Short Runner T4 TS GTX3076R Experiment
UPDATE:
I swapped in two different exhaust CASs and intake CASs (thanks Curt Brown) and it did not resolve the issue. I can rev the car to 6k under low load with no issue, but as soon as I see more than 15psi it breaks up badly. This was again confirmed with the stock ECU and Haltech. I did a pressure test and the IC piping is good. I also pulled the valve cover and did not see any issues with rocker arms or retainers.
Any suggestions are welcome.
I think I may have found the problem. If I move around the COP connector for coils 2&3 the car stalls as if the coils are not connected. This is not good because I have little patience for wiring issues.
Video of problem
Video of problem
When I swapped to the OEM ignition I could not get it to repeat while moving the wires around so I think that issue is with my wiring at the connector. I will have to redo that by ordering new connectors.
I believe I have found the issue, which is the trigger wheel smacking the pickup. I can clearly see the damage on the trigger wheel, but need to remove the crank sensor to see if it is damaged. I am not sure why the wheel would hit the sensor, but I am going to have to take some measurements next time.
I also have a leak from that large cast iron piece that attaches to the motor mount. I think it originates from the bolt in the picture and I was likely supposed to put some type of sealer on those threads. Easy fix and I don't see any oil originating from the head gasket area.
My issue is still unresolved, but I think I may have found something to investigate. I got a nice high end timing light for Xmas and decided to see if using it would shed light onto my issue
. I hooked up the timing light to the coil 2&3 signal wire(bl/gr) and got it dialed in. Realizing that I can't align the crank marks from this coil I decided to switch to the coil 1&4 signal wire. The results are the timing light can't get a signal from this wire. It is odd because no signal means no fire, but the coils are clearing firing. I can actually get a decent signal from all of the wires except the bl/yl signal wire on coil 1&4. Since those are the cylinders giving me grief I suspect this is related to my issue.
Any thoughts or suggestions for investigating further are welcome. If someone can tell me what readings (continuity to ground, 12v, etc.) I should have at each connector with car on and car off that would be great.
. I hooked up the timing light to the coil 2&3 signal wire(bl/gr) and got it dialed in. Realizing that I can't align the crank marks from this coil I decided to switch to the coil 1&4 signal wire. The results are the timing light can't get a signal from this wire. It is odd because no signal means no fire, but the coils are clearing firing. I can actually get a decent signal from all of the wires except the bl/yl signal wire on coil 1&4. Since those are the cylinders giving me grief I suspect this is related to my issue.Any thoughts or suggestions for investigating further are welcome. If someone can tell me what readings (continuity to ground, 12v, etc.) I should have at each connector with car on and car off that would be great.
I gapped the plugs down to 0.018", but it made no difference regarding WOT breakup. I performed a continuity check from the ECU connector to the connectors themselves. I also made sure there were no shorts to grounds & power for the following:
Inj #1
Inj #2
Inj #3
Inj #4
Coil 1&4
Coil 2&3
Everything checked out so I don't suspect this to be a wiring issue. I still cannot get the coil 1&4 signal wire to provide an rpm signal to my timing light.
I do notice the injectors don't all click the same and two of them are physically and audibly clicking harder. Therefore, I am sending them to FIC to have them cleaned and flow tested.
Inj #1
Inj #2
Inj #3
Inj #4
Coil 1&4
Coil 2&3
While the injectors are being sent to be cleaned & flow tested I decided to make some changes. No topmount is complete without an MPFAB CAS shield, but I did have to slightly modify to fit my setup. I also added some additional shielding to force the heat out the hood vent.
I am also shipping the compressor housing for the GTX3576r and GTX3582r to my buddy to machine for Garrett's turbo speed sensor. I will add some pics once these are complete.
I called FIC and they flow tested the injectors and everything looks good so that eliminates a potential cause. It is sad that I was actually hoping to buy new injectors.
Once I recieve the injectors and compressor housing w/ speed sensor I have a few things I will try. I should have my new data logging gear so I can monitor EGT on each cylinder to see if it is a cylinder specific issue. I am also going to hook a voltage meter to the COP power and see what the voltage is doing under load. I still can't understand why the COP 1&4 signal wire won't register with my timing light, so I will likely hot wire directly from the ECU and bypass the stock harness.
I will briefly mention something very odd with my COP connectors. If I unplug the COP and turn the car on, all three pins (+, Signal, ECU Ground) have continuity to battery ground. I then plug an LED into (+,ECU Ground) and it lights up. I go back to continuity check and I have continuity on (+) to battery ground. After a few minutes continuity with ground from the (+) no longer exists. It acts as if there is some jacked relay in the setup, but I don't see the IX has a relay and only uses a fuse.
I may have blown my head gasket with the new setup. Taking the advice of another member with similar issues I decided to pull the head since the compressor housings are being machined by my buddy for the Garrett turbo speed sensor.
Upon pulling the head I noticed that cylinder #1 (passenger side) piston was very clean and the other piston tops had carbon buildup. This would seem to indicate that coolant was leaking into the cylinder. The only clean pass I made AFRs went from 11:5:1 to 12:1:1 so I expect to make more power with this setup with only minor loss in spool. I should have the setup put back together by Tuesday.
