Short Runner T4 TS GTX3076R Experiment
Old Feb 12, 2013 | 08:57 PM
  #421
240Z TwinTurbo's Avatar
Originally Posted by SpeedAddict502
Did you ever figure out the problem with the ZR1 coils? Or did you give up on them after the Bosch ones were working so well?
I have not given up and plan to switch to a shielded wire for the signal as I believe that may be the issue. Just not high on the priority with the other mods that are in the queue...(new header, GTX3582r, R2 cams).
I spent all this time on prepping the car for E85 and the gas station that was shown to be in my town is now gone and the closest station with E85 is ~30miles away.
Old Feb 12, 2013 | 09:03 PM
  #422
Originally Posted by 03whitegsr
Thanks for more data.
I'm suprised to see the losses up top. More compression really should help at higher engine speeds.
Out of curiosity, have you played with cam timing at all? Maybe dial in some more overlap on the low end to see if it helps get rid of the surge and drops peak cylinder pressures a bit and you might be able to get some of the timing advance back.
I have not touched cam timing, but that is something I need to explore. I do run an AEM adjustable cam gear on the exhaust cam so I can make changes. As far as timing advance, I run the Orthodox pulleys and they have no timing marks. I got a nice timing light for Xmas so I will likely swap back the stock pulley to make sure the ignition timing is true to what I have in my map. The Haltech allows me to lock timing and I can then adjust an offset value to make sure timing is accurate based on my base timing map.
Old Feb 13, 2013 | 01:53 AM
  #423
_david_'s Avatar
Originally Posted by 240Z TwinTurbo
All dyno runs are done in 3rd gear.
Also on the DJ? Your car has 5 gears right? Why not in 4th?
Old Feb 13, 2013 | 04:42 AM
  #424
Yes...DJ
3rd gear is pretty standard for dyno runs, but 4th would also work. The boost response would be much quicker in 4th and present significant surge issues.
Old Feb 13, 2013 | 10:19 AM
  #425
_david_'s Avatar
Yes, the dyno chart would reflect more tq and hp at low rpm
Old Feb 13, 2013 | 10:49 AM
  #426
Lancerboy89's Avatar
Very Nice build , looking good
Old Mar 26, 2013 | 06:52 PM
  #427
I have been silent lately regarding my progress, but definitely staying busy and making changes to the setup. So my build will take the following path:
- New top mount turbo setup (fabricated by me)
- 3.5" turbo back exhaust 18g 321ss (fabricated by me)
- GSC R2's (Special Thanks to English Racing for their support)
- GTX3582r (getting lonely on the shelf)
I should have the new turbo setup done in April and will baseline the results on the dyno vs the previous short runner setup. I will then swap my S2's for the newly acquired R2's and stick it back on the dyno to show before/after with cam swap. I will finally swap to the GTX3582r for GTX SHOWDOWN PART II.
I won't be posting pics of the new turbo setup until it is complete and tested, but I did want to post a teaser shot to show you can fit a top mount with 3.5" down pipe and still have plenty of room for the AC.
GSC R2's
3.5" downpipe off turbo
Old Mar 27, 2013 | 03:21 AM
  #428
rob82's Avatar
First off great build thread, your car has been built very well. Few questions:
1. What plug gap are you running with the Bosch coils?
2. Where did you get the Bosch coils from? I've been trying to get my hands on some...
3. Where did you get those sealed relays from - i've seen them used in 24v systems not 12v though...
Sad to see the higher comp motor not make more hp... I think it's interesting that your timing numbers are similar from before to after... That would suggest that your dynamic compression has not changed. What are the chances you cylinder seal is not as good as the factory motor? Possibly poor ring package or bores out of round....
Old Mar 27, 2013 | 09:42 AM
  #429
stock plugs stock gap
Mech-Tronic
323 Coolidge Drive
Centerport, NY 11721
(631)423-0523
Squash Performance
I am actually pleased with the results considering I reduced the timing by as much as 2.5deg and achieved equivalent performance. I did also notice a slight increase in spool so the results are all good.
Old Mar 27, 2013 | 09:56 AM
  #430
03whitegsr's Avatar
It will be cool to see the difference that happens from the added runner length.
Are you using the same diameter runners?
Old Mar 27, 2013 | 10:31 AM
  #431
yes
Old Mar 30, 2013 | 01:47 PM
  #432
A few more teaser pics. I am running a single wastegate using a Tial 44mm for the new topmount TwinScroll setup. Thanks to Drifto for the advice for the divided single wastegate.
Old Mar 31, 2013 | 10:19 AM
  #433
Old Mar 31, 2013 | 11:11 AM
  #434
nollij's Avatar
Can you post some more pics and explain more how you welded that divider into the merger? Also, more pics of the routing on that manifold. It looks pretty creative.
Good work.
Old Mar 31, 2013 | 11:27 AM
  #435
