Short Runner T4 TS GTX3076R Experiment
Old Dec 21, 2012 | 04:37 AM
  #361
240Z TwinTurbo's Avatar
Originally Posted by JohnBradley
It won't and the MR is different yet.
Thanks, back to 'Plan A'
Old Dec 21, 2012 | 12:02 PM
  #362
UPDATE:
I am running a 1/2" stainless hardline under the car in place of the stock return. I will use this as the new supply line and the stock supply line as the return. Should have it finished and installed this weekend. I have weld-on stainless AN fittings for each end of the hardline.
Old Dec 21, 2012 | 01:07 PM
  #363
03whitegsr's Avatar
Nice work. That's a lot of fuel line with an "OEM" look. Did you use an annealed tube?
Any reason you are going with weld on ends over tube nuts and sleeves?
Old Dec 21, 2012 | 02:23 PM
  #364
I have a Synchrowave 250 TIG welder at my house so it is easy and I prefer a welded joint vs nut and sleeves.
The tube is 304 stainless with 0.049" wall. This stuff is stiff as heck and requires a special tool for bending. I purchased the tool used off ebay for $50, but they are $110 new for the one I use. Even with the tool it takes a lot of force to bend the tubing.
The hard line is done and I did make it abbreviated at the front of the car to avoid the headache of making it run to the engine compartment. I terminated it about 1" as it angled up from the bottom of the car so I could easily access the connection with a wrench. I will post pics once the AN fittings are welded and the hardline installed.
Old Dec 21, 2012 | 02:36 PM
  #365
Sharkbite2000's Avatar
That's wild.
Old Dec 21, 2012 | 03:17 PM
  #366
ETS Michael's Avatar
looks good!
Old Dec 22, 2012 | 10:55 AM
  #367
I have been fighting to remove the fuel hose on the factory supply line that connects from the hardline to the fuel rail. I purchased the adapter for the end of the factory supply line to make it a -6 AN. Just hard to get a good angle on it with the wrenches.
Taking a break I found a good place to mount the ethanol sensors...
Old Dec 22, 2012 | 02:29 PM
  #368
That was fun...
Old Dec 22, 2012 | 09:11 PM
  #369
03whitegsr's Avatar
Yeah, I've bent up annealed 3/8" stainless line before with a bender very similar to that and even with it annealed, it was still fairly difficult to bend. Your bender more beefcake then the one I have.
Old Dec 23, 2012 | 11:14 AM
  #370
half way done...
Old Dec 24, 2012 | 02:13 PM
  #371
Built short block installed so I should have this finished in a few days.
Old Dec 24, 2012 | 02:38 PM
  #372
JohnBradley's Avatar
Nice. Looking forward to seeing what this does turned up Have you been logging EMAP at all?
Aaron
Old Dec 24, 2012 | 03:14 PM
  #373
Aaron
Not yet, I will log emap with the new manifold I plan to build in Q1.
Old Dec 24, 2012 | 04:45 PM
  #374
Nice. I was curious based on some testing we have done but as always lots more testing to do. Also as a side note we are ordering the Garrett turbo speed sensors. The Series 2 that is going to go in my car can log it.
Old Dec 25, 2012 | 04:44 PM
  #375
New hard line is installed. It is hard to get a good pic with the car on jackstands.
One of my Christmas presents should be arriving Friday to finish the new fuel system...
