Short Runner T4 TS GTX3076R Experiment
notice the removal of black coating around the bore on the headgasket.
This is common on SR20's with the cylinder liners moving.
It seems you are have either bore movement or head movement.
What headstuds and torque settings are you using?
I run the MAP Ultimate Duty H11's torqued to 95-100 ft/lbs. I am suspect of my torque wrench so I will borrow one that is known to be good. I will run the car through a few heat cycles and let sit overnight. I can then back each bolt off approximately an eighth to a quarter turn, then re-torque to spec one at a time and in sequence. I pushed it too much before I decided to pull out the laptop and actually log wideband AFR's, which were lean.
I've seen guys induce problems by backing off head bolt torque to retorque instead of just going back over and checking them.
Or leave them 10 ft-lbs low to start with them bump them up that 10 ft-lbs after a heat cycle or two.
With the H11s, even at 85 ft-lbs, you are still above factory torque level.
I Am actually having similar ignition misfires myself, im running a Vipec. I might start looking at the exhaust cam sensor as what JohnBradley said was interesting.
Get an old plug and open up the gap and then it should show up on the timing light, iv been down this path before.
240Z TwinTurbo
196
Nov 3, 2015 12:29 PM
240Z TwinTurbo
Mar 18, 2014 02:36 PM
240Z TwinTurbo
Nov 10, 2013 09:55 PM
240Z TwinTurbo
Oct 8, 2013 07:21 AM
240Z TwinTurbo
May 4, 2013 12:49 PM
