Short Runner T4 TS GTX3076R Experiment
Old Mar 31, 2013 | 11:32 PM
  #436
riceball777's Avatar
are u intrested in selling your gtx3576r because your up grading to the gtx3582r
Old Apr 1, 2013 | 05:09 AM
  #437
240Z TwinTurbo's Avatar
Maybe, need to see how the GTX3582r performs vs the GTX3576r and then make a call.
Old Apr 1, 2013 | 02:52 PM
  #438
UPDATE:
The new top mount setup requires clearance for the IC pipe so I had to fabricate a new front motor mount and bar. I decided to approach it differently than what I had seen by placing the isolation mounts at the body. This left me a lot of room between the header and front bar for the IC pipe.
Old Apr 2, 2013 | 07:06 PM
  #439
one more bung to go! Received the 3.5" vband clamps today so I can start the exhaust and be on the home stretch.
Old Apr 2, 2013 | 07:09 PM
  #440
Grimgrak's Avatar
If only I read this thread instead of spending 6 hours on the dyno trying to figure out why it was making crap power
Old Apr 2, 2013 | 09:25 PM
  #441
nollij's Avatar
That's a lot of bungs... AFR for each runner, stock O2, EGT post turbine, Exhaust pressure, what is the last one for?
Old Apr 3, 2013 | 12:21 AM
  #442
Grimgrak's Avatar
FYI with a ams t3 manifold, .63 housing and gt3076r. I too was surging like a **** at part throttle and high throttle below 4-5krpm. But I use a tps based signal to trigger my boost solenoid to close the bottom port. 3.5V works great for me.
Old Apr 3, 2013 | 07:08 PM
  #443
UPDATE:
I was able to finish the lower IC pipe today so one more thing completed. I do have to order more thermal wrap to protect it from the exhaust. The mockup turbo is actually the GTX3582r because it wanted some fresh air after sitting on my shelf this past year.
I also started the downpipe and made decent progress. I should have the downpipe done in a few days.
Old Apr 4, 2013 | 03:40 PM
  #444
I am no longer a fan of ACD.
Old Apr 4, 2013 | 04:23 PM
  #445
211Ratsbud's Avatar
Lol @ acd.
Beautiful piece
Old Apr 5, 2013 | 04:39 PM
  #446
Almost done with the downpipe...
Old Apr 6, 2013 | 12:05 AM
  #447
Grimgrak's Avatar
No flex section?
Old Apr 6, 2013 | 03:02 PM
  #448
Originally Posted by Grimgrak
No flex section?
I am putting one after the downpipe.
I was able to finish all the downpipe today including mounts, PVC evacuation and remaining 02 sensor bung.
I was also able to make the new radiator mounts for the Mirage radiator. I ordered a piece of 1/4" 6061 plate and reused the stock rubber mounts. Once they are powder coated they will look great.
Old Apr 10, 2013 | 01:06 PM
  #449
OK, 3.5" downpipe done and permanently installed.
I was able to finish a critical part of the build, which was the turbo drain line. I ended up hybridizing the stock turbo drain with some 3/4" SS tubing. First time to actually purge a part since I did not have a way to clean off the Solar Flux B and did not want it in my oil.
Old Apr 10, 2013 | 05:45 PM
  #450
211Ratsbud's Avatar
How do you weld the v band without warping the flange. My last v band attempt failed miserably
I want to divide my v band into 1/4's so I can have 4 individual feed tubes for my anti lag set up. I'm thinking water jetting a plug with 4 holes in it to fit inside of the flange is my best bet .
Does the bottom of the mirage radiator line up?
