VALVES HIT PISTONS: New Built 2.4L / IX Head / Cosworth M2 Cams / Wiseco 9.7cr Piston
In other words, set the cosworth cams to stock cam timing (as opposed to the timing recommended on the cosworth cam card), and then adjust for the 2.4L (-3.75 on the adjustable gear)?
Honestly Idk. I have asked a buddy with a 2.4 and his answer was as useless as **** on a bull. I will see if i can come up with an answer for you though. Maybe someone who has a 2.4 can chime in. I don't want to give you an answer and it be wrong rather then not answer and search for the correct one.
I'll probably do an AMS gasket this time. At least until i know it's running right.
The problem i suspect comes down to the tune. The tune was NOT intended for anything but a break in. The person driving the car put his foot into it. I wasn't even logging the car when it happened . So it's likely going to get an AMS 2.4 gasket, and this time the car isn't moving without being logged.
Also, when taking the head off the car, the nuts on the head studs were less than the tq they were installed at. hmm
PE, but i don't think it was the HG's fault. I'm going to the AMS b/c it's cheaper and I don't want to pop another one at that price. My HP goals are only 550whp (dynojet) so the AMS one should suffice.
So if I am going to disregard the cosworth cam card, how are people setting cam timing? Timing marks? Does anyone have cam info for stock timing??
Thanks.
Thanks.
R18eclipse
27
Aug 30, 2018 11:58 AM
doncarbone
10
May 29, 2017 05:20 AM
maperformance
Evo 'For Sale' Engine Internals and Drivetrain
Jan 22, 2015 12:05 PM
pistonless
25
Oct 10, 2011 04:05 PM
Evokid03
Nov 18, 2010 08:04 PM
