Weird problem with turbo
Old Dec 10, 2011 | 09:30 AM
boczo777's Avatar
First of all I am sorry for my english/explanation, my problem started when i switched from evo 9 turbo to HTA71
i think it is called sputtering, on certain boost level it feels/hears like there is solenoid put on pipe and it opens and closes really quick, than when it hits 20psi it stops all the way to maximum 26psi, car pulls great, was tuned, made 400whp no problems(could do more but injectors are maxed out), i would not really care about it but i want to sell car and i want it to be mechanically souund
thank you
Old Dec 12, 2011 | 06:33 AM
boczo777's Avatar
bump anybody??
Old Dec 12, 2011 | 06:44 AM
escodotcarter's Avatar
When you swapped turbos did you get retuned for it? You could be hitting a boost cut due to higher load. Check your spark plugs too.
Old Dec 12, 2011 | 07:05 AM
boczo777's Avatar
yes, it was tuned after turbo was replaced
Old Dec 14, 2011 | 07:35 AM
evopwned's Avatar
I can't make out what you're trying to say, honestly.
Old Dec 14, 2011 | 10:26 AM
sk8terdude929's Avatar
Does it sound like your BOV is opening and closing? Does it sound like it is realesing air when it opens?
Old Dec 19, 2011 | 05:00 PM
triple L's Avatar
it is called surging!! it happens when u r at partial throttle &/or wide open throttle... this happens when u don't have anti-surge compressor or really stiff spring BOV... this happen to me when i got my car tuned with 9 turbo....only surges at part throttle
Old Dec 20, 2011 | 06:58 AM
boczo777's Avatar
ok, so what are the ways to fix it???
Old Dec 20, 2011 | 07:02 AM
cheb evo's Avatar
Do you have an adjustable DV (Forge RS, etc)? Try playing with the load on the spring for the DV to see if you can minimize the issue. Try cranking it all of the way down first.
Old Dec 20, 2011 | 07:03 AM
boczo777's Avatar
i got oem evo 9 bov
Old Dec 20, 2011 | 04:37 PM
cheb evo's Avatar
If you have a friend that is willing to swap out his BOV with yours, give it a try...rule that out first.
Old Dec 20, 2011 | 07:27 PM
3K's Avatar
3K
Its surging because your in too high of a gear and too low of a rpm to start boosting. That's what happens when you switch to a larger turbo.
Adrenalinejunke
Jul 5, 2012 07:46 AM
awdordie
18
May 6, 2012 07:48 AM
awdordie
11
Aug 18, 2011 12:42 PM
Mauricio Evo IV
35
Dec 8, 2010 05:54 PM
vampire
17
Jul 27, 2006 08:24 AM
