Stock Turbo Removing Exhaust Housing
Old Dec 12, 2011 | 10:54 AM
IBAUCLAPlaya's Avatar
So I snapped the two Manifold to exhaust housing bolts. I took the entire turbo assembly off the car and took it to a machine shop to have them drilled.
The guy pulled off the exhaust housing (just undid the clamp and removed the wastegate arm). Is there any secret to putting this back together once done? Or do I just hammer it down, clamp it and reattach the arm?
TIA
Old Dec 12, 2011 | 10:57 AM
milford's Avatar
there is a set pin to line up with is hole.. then clamp it back together
Old Dec 12, 2011 | 11:34 AM
Not sure what that means? Pictures?
Old Dec 12, 2011 | 03:33 PM
AWDBus's Avatar
One side has a small pin on the housing, the other side has a small hole, just line them up. Look at it and you should understand. Then re-tighten the clamp and your done. You really cant mess it up unless you try to hammer it on.
Old Dec 13, 2011 | 01:02 PM
turbolarry's Avatar
This is a regular 16g, but it show's the pin (small circle) that needs to be aligned with the small home in the turbine housing
Old Dec 14, 2011 | 07:26 AM
evopwned's Avatar
Need good tools, but it is pretty self explanatory.
LakerRaider
Jan 20, 2017 10:49 PM
railgunner50
14
Jul 25, 2013 09:41 AM
5speedwtneed
11
Jul 5, 2013 11:57 AM
thenewguy
Evo X How Tos / Installations
Dec 16, 2010 12:52 PM
EVOXSILVER
14
Nov 27, 2008 08:03 PM
