Why a turbo timer is NOT useless
Old Dec 17, 2011 | 01:23 AM
  #76
craigybaby37's Avatar
I dont have one on my evo 5 but a mate had one on his celica GT4 and when he used to give it a foot full the manifold and hot side would glow cherry red..........he just used to leave it 10 mins at idle to cool it down but say if he was parking the car up somewhere and going off would a turbo timer not come in handy then???
Old Dec 18, 2011 | 11:34 AM
  #77
hokiruu's Avatar
I guess that would depend on if his manifold and hot side are ALWAYS glowing red hot, even from a 5 minute run to the store, or just because he flogged the car to that point once and showed you.
Old Dec 18, 2011 | 11:46 AM
  #78
silver9mr's Avatar
iv never had one in my car and never had issues with it
Old Dec 18, 2011 | 11:57 AM
  #79
Boosted Tuning's Avatar
A turbo timer is USELESS because No one BOOST into their parking spot at home or at the store.
When you go home, you usually "slowly" cruise though your neighborhood, to your house. This slow cruising time is enough cool down time. When you go to the store, you dont boost into you parking spot. You drive around "slowly" and find a spot. This is adequate cooling down time.
Old Dec 19, 2011 | 01:31 AM
  #80
EVO8emUp's Avatar
Don't forget.... Mid RPM, low load, steady state (interstate) driving will cause it to glow also. It's not just wot pulls.
If you want to "cool it down", it has to be low RPM, low load cruising.
Regardless, I stopped using them in 1998. Never had one turbo failure as a result of coking.
Old Dec 19, 2011 | 08:26 AM
  #81
Live4Redline's Avatar
If your manifold is glowing a solid red you have far more issues then a turbo timer, you may need to start your own thread.
Old Dec 19, 2011 | 08:41 AM
  #82
95gst16g's Avatar
Lol the best use I found for a tt living in the pnw on cold mornings is set that sucker to 10 mins start the car go back in the warm house.Then when I get in my car I'm not freezing cold
Old Dec 19, 2011 | 03:04 PM
  #83
kiley_sean's Avatar
This and when I start the car and forget something in the house (and need the keys). I use it more as a babysitter for the car than anything else.
Old Dec 19, 2011 | 09:27 PM
  #84
EVO8emUp's Avatar
No, you just don't know what you're talking about. No offense.
There is no reason to get people all freaked out because of misinformation.
Old Dec 20, 2011 | 04:37 AM
  #85
germanmike954's Avatar
I've had turbos pushed to 50+ psi and turned off right after a pass and never seen a problem, turbo timers are pointless
03whitegsr
23
Nov 19, 2016 10:06 PM
FreakEVO
Nov 5, 2016 02:55 AM
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
MINO
10
Jan 16, 2008 06:53 AM
