What turbo should I get
Old Dec 21, 2011 | 06:31 PM
lopillo_evo's Avatar
Veteran: Army
Hey guys I'm deploying next week and I'm about to go crazy on parts for my car is a 2003 Evo Gsr my goals are 500-600awhp and I don't know what turbo should I get. Any help will be really appreciate
Old Dec 21, 2011 | 06:47 PM
sparky's Avatar
Do you want a bolt-on, stock framed turbo, or do you want to do a full kit? What fuel will you be running(E85, pump, Meth, etc)? What will be the end use of your Evo(DD, Drags, Auto-X, HPDE's)? Finally, how much money do you want to spend on the turbo and ancillary bits and pieces?
Old Dec 21, 2011 | 06:58 PM
Veteran: Army
Well I will love a full kit I'm thinking on spend anywhere between 7k-8k. Use it has a dd but take it auto x once in while. Pump gas 91 and what you think meth or e 85 there is only one station that sale it here in El Paso.
Old Dec 22, 2011 | 07:26 AM
thepoint4life23's Avatar
How much power you looking to make. stock block
Old Dec 22, 2011 | 07:42 AM
phyzy's Avatar
I'd want to know more than the turbo, what supporting mods do you have? Throwing a big turbo is not the big deal, do you have a supporting motor, fuel, tune, trans, etc.?
Old Dec 22, 2011 | 11:45 AM
Veteran: Army
I'm planning on a BR stage 3 head, GSC 2 cams, 1450cc FIC injector, walbro fuel pump, AEM fuel rail, Automotive regulator, shep tranny, probably BR 2.0 shortblock, ETS FMIC with complete piping, ARP head studs, I want 500-600awhp What you guys think with this mods, what hp can I get with this mods?
Old Dec 22, 2011 | 12:42 PM
sparky's Avatar
?How conveniently located is that one E85 station to your house or work? I would look into a dual switchable map setup with a 91 octane daily tune and a E85 "Race" tune. I would do a BR 2.3 high rev build. Go with either of the following bolton turbos depending on preference: FP BB HTA Green, FP BB Red, CBRD BBKB-BB, a MAP EF3, or the ubiquitous BB CBRD BBK. Run FIC 1450's and a Buschur staged double pumper.
I realize that the BBK is a bit of a stretch for low 500's, but it is a great all-around turbo. The Green will get you into the low 500's with your projected build. The Red will carry you into the mid 500's on E85. The BB BBKB should fall midway between the Red and the Green power wise. The M.A.P. EF3 is an intriguing option that is putting out some nasty power as well. There is an upcoming BBK-C, but I don't have any info on that one yet. I just wouldn't go much larger than any of the above turbos if I was considering doing any parking lot(Auto-X) events.
Old Dec 22, 2011 | 12:51 PM
fre's Avatar
fre
Its going to be hard to make the power you are looking for and have a good auto x car. You will probably be beaten by lower powered evos in auto x. I have a 3582 setup and I get stomped by stock engine evos in auto x heh. I would say you could be in the 400whp range and still be competitive with the stockish evos if not beat them, but any higher than that and good luck, unless you are the brake boost master.
Now move on to road course or hill climb racing (real world conditions) and you have another story.
Old Dec 22, 2011 | 01:16 PM
Go bb red
ChrisCarey's Avatar
Additional displacement will obviously help spool, we've seen 2.3L powered EF3 cars spooling in the late 3000's which should be pretty manageable for AutoX.
Old Dec 22, 2011 | 02:05 PM
DJAfterShok's Avatar
FP red or Black. Just port the exhaust manifold and you will have a sleeper.
Also get some cams, fuel injectors, intercooler, new piping and a new clutch.
Old Dec 22, 2011 | 03:50 PM
Veteran: Army
Thanks for the help guys this really really helps me on my decision I will probably change my mind and try some road course and go with a 2.3L. Sparky the gas station is far from work and house
Old Dec 22, 2011 | 03:54 PM
phyzy's Avatar
In my opinion, if you have the funds, +1 for a stroker motor.
Old Dec 22, 2011 | 03:58 PM
600+hp's Avatar
https://www.evolutionm.net/forums/ev...omparison.html
2.3 L RPM + HTA 3076r
check out the 40psi graph on pg. 4
Old Dec 23, 2011 | 07:41 AM
Veteran: Army
Wow that's freaking impressive I think I found my setup thanks 600+hp
