fuel pump wire with high/low voltage circuit
Old Oct 19, 2016 | 01:30 PM
  #211
dr_latino999's Avatar
Veteran: Army
Originally Posted by mrfred
January 6, 2012 Update:
Here is the table in the 88590015 ROM for controlling the low/high voltage crossover point:
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="3fce" type="2D" level="1" scaling="Load8">
  <table name="Engine Speed" address="6b7a" type="Y Axis" elements="10" scaling="RPM"/>
</table>
Does anyone have the code for controlling crossover for the 96530706 ROM?
Old Oct 19, 2016 | 08:24 PM
  #212
CDrinkH2O's Avatar
Yes. Will post up when I get home.
Old Oct 20, 2016 | 12:17 AM
  #213
Veteran: Army
Is it this block of code?
Originally Posted by L-op
96530006
Code:
<table name="Min Load for Fuel Pump High Voltage" category="Fuel" address="4568" type="2D" level="1" scaling="Load8">
<table name="Engine Speed" address="6576" type="Y Axis" elements="10" scaling="RPM"/>
</table>
<table name="Low/High Voltage Transition Hysteresis" category="Fuel" address="1A74" type="1D" level="1" scaling="Load16"/>
https://www.evolutionm.net/forums/ec...ml#post9891833
Old Oct 20, 2016 | 06:57 AM
  #214
211Ratsbud's Avatar
Would someone be willing to make a harness and sell?
Would someone be willing to make a harness to sell? I sold my evo to a friend, I don't have time to do this kind of stuff. Or the general knowledge. Would prefer something high quality etc.. as much done cleanly as possible
Old Oct 20, 2016 | 09:34 AM
  #215
mrfred's Avatar
I've talked with Matt@Spoolinup about selling a nice harness using the pressure switch method that is easiest to implement, but I don't think taken any action. I suggest that people send him emails letting him know that there is a market for this.
Old Oct 20, 2016 | 11:56 AM
  #216
211Ratsbud's Avatar
I'd particularly be interested in one that is ecu triggered. The car is using a vi-pec with much more flexibility.
Where in the car does the ecu signal for the high voltage relay "daylight"
Old Oct 20, 2016 | 12:09 PM
  #217
211Ratsbud's Avatar
Ohh.. didn't see the issue you had with the circuit @mrfred
Old Oct 20, 2016 | 12:12 PM
  #218
Biggiesacks's Avatar
thing is the ecu signal turns the relay off, which makes using it tricky, doable but tricky.
Old Oct 20, 2016 | 01:09 PM
  #219
211Ratsbud's Avatar
Ahh the perks of standalone
Old Oct 20, 2016 | 01:17 PM
  #220
Veteran: Army
Drove around for 80 miles today using the pump crossover code, I'm surprised I forgot to add it for 6 months. Worked as expected.
Old Oct 21, 2016 | 12:09 PM
  #221
CDrinkH2O's Avatar
Yep that is it.
Old Jan 21, 2017 | 04:21 AM
  #222
Installer88's Avatar
Has anyone reported backfeeding of power and the fuel pump running after the car is off with mrfred's hobbs switch wiring?
Old Jan 21, 2017 | 12:23 PM
  #223
Raceghost's Avatar
MRFRED,
Hey, I am looking at doing a rewire, but in a little different fashion. I am looking to rewire the Hot lead from battery to Relay 3. This is the Hot lead, that once the Relay is activated, feeds the Hot lead to the Fuel Pump, which I believe is the White wire coming off of Relay 3. Question is, what is the HOT Wire to Relay 3 from Battery? Having issues reading the color code designations of the plug that connects to Relay 3.
Can you help? Anyone else know?
Old Jan 22, 2017 | 06:46 AM
  #224
patkelley's Avatar
This setup with the hobbs switch and relay under the dash works perfect for me.
Old Jan 23, 2017 | 05:11 AM
  #225
TrendSetter's Avatar
Originally Posted by Raceghost
MRFRED,
I think you may experience a minimal performance increase because the relay is on the firewall so you still have the stock wire going from the firewall to the pump. it will be interesting to see how well it works though.
