fuel pump wire with high/low voltage circuit
Im confused about how the hobbs switch works. How does it know what pressure you're getting in order to activate the high volt setting? I see there is a vac/press port on the hobbs switch but I didn't see anyone mention hooking it up to a boost source in this thread, so is it not used?
I'll add that the pressure switch is not meant to be a power relay. It only serves to complete the circuit on the control side of a power relay as shown in Biggiesacks diagram.
I'm actually running mine as a relay with an line fuse off the battery. I couldnt really think of any downsides to running it this way. If the switch failed, it would be stuck on continuous "on" until I disconnected the power wire from the switch or continuous "off" and would run the pump off factory wiring as it was before I ran the 10ga wire inline with the OEM wiring. If it got too hot, it would pop the fuse. I will setup an AFR failsafe and a Fuel Pressure failsafe through my Haltech just in case though..
a hobbs switch isn't meant to move current like a relay is, so it will be a bottle neck at best. Specifically the spoolinup one lists its current rating at 15amps, which isn't even good enough for a factory pump.
I'll be installing a 450 pretty soon on my evo and I think I'm going to try and make a 3 stage voltage system for it. I'll add a resistor to the factory high stage to make it into a medium and then use the hobbs switch for the new high. I think I'll shoot for 20psi activation on the hobbs switch. If it works out I'll post some stuff about how I implemented it.
I figured this is already happening as a byproduct of triggering off of a hobbs switch, and that the factory high stage can only deliver so many amps to the pump. I am going to try and just be more deliberate with how many amps are delivered to the pump during that "middle" stage.
I kind of just had this idea when I was thinking about how I want to go about installing this new pump. I'll post way more details as I get further down the rabbit hole. I mostly wanted to throw this idea out there to see if anyone thought I was off my rocker. I'm still researching my parts order and I have to logistically figure out where the best place to even put the new resistor is going to be. Before that even I need to figure out the physical dimensions of the resistor, which means I need to settle on a part, which means I need to figure out what resistance I want to try.....and it pretty much keeps going down the rabbit hole like this lol. I am kind of half way between the conceptual stage and the planning.
Gotcha. I try reading through this stuff and it's WAY over my head. I'm still lost with the normal high/low rewire. I can tear down an engine and reassemble with no problem, but ask me to wire some **** and it's a wrap lol. Really just need to find someone local to walk me through while I'm doing it.
Oh yah totally, I know people have been installing these things for a long time and making it work. I even purchased a radium jet pump to replace the factory one, so I'm sure i especially wouldn't need to do this. I just enjoy tinkering with stuff. Since I'm already doing this I figured I would give it a shot and see how it turned out. It's a simple enough thing to do (I think) that even very minimal gains in efficiency might make it worth it (to me anyway).
