what head gasket for 4g64 in evo
Old Jun 30, 2013 | 04:54 PM
  #31
Wheatley's Avatar
I bought a bored oem gasket through ams when I started my build and it has worked flawlessly. Any link on buying more if they wont sell them?
Old Jun 30, 2013 | 08:02 PM
  #32
batty200's Avatar
I just used a stock 4g64 MLS EVO gasket. Hopefully it holds up.
Old Jul 24, 2013 | 05:36 PM
  #33
Wheatley's Avatar
How many layers and how does the construction compare to the evo8 gasket?
Someone referenced this gasket MD332035, its only $17 cheaper than the oem 8 gasket so I'm curious how the construction is. As long as its not thinner or a lesser quality material it should be good to go.
Old Dec 31, 2013 | 08:57 PM
  #34
howell's Avatar
Any more feedback on what gasket to go with? Any personal feedback please mention what psi/power level you are at and also what studs are you running. I plan to be around 650-700 whp
Old Dec 31, 2013 | 09:49 PM
  #35
boostawd16's Avatar
The best you can go with for that power level and price is an oem. Just get the gasket and bring it to a machine shop to bore match it and you'll be good to go
Old Jan 1, 2014 | 01:19 AM
  #36
batty200's Avatar
It is super thin and two layers. Seemed to hold perfectly for me. No issues. Only 45 shipped from Mitsubishi parts.net.
Old Jan 1, 2014 | 11:14 AM
  #37
howell's Avatar
I am 88mm bore, so that is too wide to bore the 4g63, but I could use a 4g64 MLS and bore it out a little. But from what I understand it is thinner. I also plan on running the map h11 or running the arp 625's
Old Jan 1, 2014 | 12:44 PM
  #38
SmurfZilla's Avatar
I've used Cometic and Power Enterprises. Im now on the OE one from AMS
Old Jan 3, 2014 | 10:50 PM
  #39
MAD8's Avatar
I run a JE. So far so good. Seems like a very well constructed piece.
Old Aug 27, 2014 | 01:13 PM
  #40
EvolutionIXMR06's Avatar
Veteran: Army
How's your JE gasket holding up? I just bought one, and plan on using it for my 2.4LR build!
Old Oct 11, 2015 | 05:05 AM
  #41
4ukc's Avatar
I used cosworth it is exactly 87mm, all OEM are 87,5 and that stops me, cometic is junk 100%.
any one has part number for OEM head gasket that is exactly 87mm, Evo 8 head?
Old Feb 11, 2017 | 09:57 PM
  #42
Ian0611's Avatar
I'm in the same boat. Also looking to do a 2.1 so if anyone has any updated info to share about the HG or anything else related to the 2.1 I'd greatly appreciate your input.
Eusebio Ponce
17
Jan 7, 2021 03:23 PM
jspecteggy
18
Mar 7, 2018 09:14 PM
maxroach
Jun 3, 2017 07:00 PM
nomnom
May 30, 2017 05:58 PM
lghtngyello03
Feb 6, 2017 11:00 AM
