Intercooler question
I can relate to what Michael @ ETS mentioned in his post about the high efficiency core allowing the tuner to run more timing/boost at the top of 3rd gear. This allows for a safer more powerful tune.
so which is better 3.8 core or 4inch core and whats the best intercooler pipe size 2.5 or 3 inch on stock engine or these this matter and could i have a 2.5 licp and a 3 inch uicp or would it define the point a 3 inch upper pipe
On here it is pretty much a foregone conclusion that the Garrett 3.8" core is a highly efficient heat exchanger. It is used by Buschur and CBRD, and can be requested from ETS.
ETS has developed a new core design which they claim is extremely efficient. This can be had as a true 4" thick core. The new ETS cores are also available in thicker 5" and 6" versions and thinner versions as well.
Incidentally, Garrett does manufacture a 4.5" core which Buschur used to employ in producing his BFIC intercooler.
(Competitor)
/\ - Fin packs only transfer heat at the very tip.
(ETS)
TT - We get double the area of fin contact with the heat transfer plate which results in greater heat transfer area.
18 Charge Rows (ETS) vs 14 Charge Rows (Garrett)
That's a quick run down.
Thanks!
Michael
UUmmm. Thanks for the info Ratster, my friend. I know very little about JMFab personally. What I do know about them I have learned on here. They apparently are a top notch outfit. I did not mean to exclude them from my short list. If CBRD uses their services then they must be good. Anyway, thanks
No prob i have the 3.8 core and it fit completely unmodified in my bumper and beam. Important for some.. although anarchy 99 has me digging a 5" ets core haha
evodave
11
Nov 4, 2004 10:34 AM
