Setup Help?????
Old Jan 30, 2012 | 10:47 AM
  #31
B.J.@ToxicFab's Avatar
Originally Posted by projektevo9
@ toxicfab do you make a manifold to fit the fp3586hta?
Yes do we, Collin recently finished a full kit for a local customer that would work with that turbo. Quickest way to get a hold of us is via PM, if you have any questions, let us know!
Old Jan 31, 2012 | 10:23 AM
  #32
projektevo9's Avatar
Bump any other suggestions on post # 12 setup options ? What Pistons and connecting rods and head gaskets are everyone running ? Acl the only way to go with bearings? Also my friend mentioned arp l19 headstuds what is the difference between them and stnd arps . Thanks
Old Jan 31, 2012 | 11:01 AM
  #33
maperformance's Avatar
L19 and H11 head studs are a tool steel stud instead of 8740 standard chromoly. The L19/H11 stud can handle more torque when assembling and more abuse over the standard ARP's.
Here is some more information;
http://www.maperformance.com/map-ult...11mmhdstd.html
Pistons - We are a big believer in Wiseco 1400HD pistons when looking to make anything over 600whp. You will see a ton of people running these pistons, and for a good reason.
Rods - Will depend on the overall power goal for the car, however there is a few different options. Once you get everything narrowed down as far as power and goal. Picking a rod will be very simple.
Old Feb 4, 2012 | 12:50 PM
  #34
Bump any connecting rod suggestions if I go w. Weisco 1400hds. Sounds like a stupid question but what else should be replaced during a build belts, ect ect thanks
Old Feb 5, 2012 | 08:30 AM
  #35
CurseDSM's Avatar
As Adam says rods are kind of a preference. Map rods seem to work, or Manly rods are used a ton as well. Belts for a big build should be all kevlar. No other way around it being its just added insurance. Gates is what I have always used with good success. Good quality fluids, good clutch, and probabily the best one a good quality tuner. That will usually make or break your build.
Old Feb 5, 2012 | 08:53 AM
  #36
If the power goal is 600whp+ safely, go with a set of Ibeams.
http://www.maperformance.com/maperfo...-5900mit7.html
That is our rods, built for us by Howard's. The same ones Cursedsm mentioned above. Uses a early DSM 6-bolt bearing that is wider than the factor EVO bearing. Supports more load than the standard bearing and has products some very high rev's for us without any issues.
Old Feb 5, 2012 | 09:07 AM
  #37
CurseDSM's Avatar
Those will be the rods I go with when I decide to build a motor for sure.
Old Feb 5, 2012 | 09:03 PM
  #38
Okay guys so I think this is my revised list there are a few questions in there,
Does anyone know if they make an v band o2 housing?
are there any local machine shops that do good work around central pa that anyone knows of?
Should I get bigger valves?
Intake Manifold Suggestions? Im running a 75mm TB
Thanks Again Folks
Internals/Bottom End/Head
Headstuds- L-19's $267.95
http://www.lancershop.com/customer/p...&cat=93&page=1
Mainstuds- ARP Main Studs $62.95
Main Bearings- ACL Race Main Bearings $53.81
http://www.extremepsi.com/store/prod...cat=255&page=1
Rod Bearings-ACL Race Rod Bearings $32.01
Balance Shaft Eliminator Kit- AMS Balance Shaft Eliminator $359.95 (ADD PULLEY ELIM)
Head Gasket- $68.99
http://vr-speed.com/store/mitsubishi...et-p-1116.html
Springs & Retainers- GSC Beehive Springs W/ Titanium Retainers and Chromoly Spring Seats $399.50
http://www.maperformance.com/gsc-pow...train-kit.html
Valves & Stems Seals- Supertech Standard Valves & Stem Seals $226.99/$23.99
Stem Seals http://vr-speed.com/store/supertech-...ls-p-2225.html
Valves http://vr-speed.com/store/supertech-...rd-p-1259.html
Pistons $555.99
http://www.maperformance.com/wiseco-...-evo-4g63.html
85.5mm/20 over--9:1 compression--7 bolt
Connecting Rods $824.99
http://www.mellonracing.com/index.ph...roducts_id=960
Cams -GSC S2 Cams $540.00
http://vr-speed.com/store/powerdivis...s2-p-2058.html
Cam Gear-HKS Adjustable Cam Gear- (X)
http://www.cimotorsports.net/motor-s...-evo-4g63.html
FUEL SYSTEM
Fuel Pump-Buschur Racing Double Pumper $515.00
https://secure.buschurracing.com/cat...870d661aebb4f0
Fuel Injectors-Injector Dynamics 1000cc Injectors $457.50
http://www.amazon.com/Injector-Dynam.../dp/B0051DS1Z2
Fuel Rail-AMS Fuel Rail $189.95
http://www.maperformance.com/ams-fuel-rail-evo.html
Fuel Pressure Regulator-Aeromotive A1000 FPR $159.99
http://www.maperformance.com/aeromot...regulator.html
(Add Map Stainless Steel fpr line kit 84.99)
IGNITION
Coil On Plug-Spoolin Up COP System $429.99
http://www.spoolinup.com/
http://www.maperformance.com/spark-t...tion-ix-9.html $1222.17
INTAKE
Intake- Perrin Intake $242.99
http://www.maperformance.com/perrin-...int-220bk.html
Intake Manifold- suggeestions?
Throttle Body-Boomba 75mm Throttle Body $465.00
http://www.amsperformance.com/cart/b...ttle-body.html
FMIC-ETS 3.5 Front Mount & Piping (X)
http://www.extremeturbosystems.com/E...ooler-Kit.html May upgrade to a 4"
EXHAUST
Exhaust Manifold- Shearer Fabrications V Band EXhaust Manifod $1045.00
http://www.shearerfab.com/products.php?itemid=210
Exhaust-AMS TBE (X)
http://www.amsperformance.com/cart/A...k-Exhaust.html
o2 Housing- Need a V Band O2 Housing ANY SUGGESTIONS on this one?
Turbo-Fp3586HTA $1,799.00 (82/ar t3 tial v band)
http://store.forcedperformance.net/m...e=Lancer-Turbo
Transmission
Transfer Case/Tranny- Built by John Shepard
Quaife lsd in the transfer case for sure. This is $1244 with the bolt upgrade and all parts and labor.
The basic street strip $895 package will be fine for your needs but we will want to alter the gear ratios to give you a taller 3rd and 4th gear with your power level. I assume this is a 5 spd so this will add $350
(X) Clutch Line-Ams Upper & Lower SS Clutch Line http://www.amsperformance.com/cart/A...utch-Line.html
(X) Shifter Bushings-Bushur Racing Shifter Base & Under the Hood Bushings https://secure.buschurracing.com/cat...eadfc34043c5c7
(X) Clutch-Exedy Twin Disk http://www.customcarscentral.com/exd...o-viii-ix.html
MISC/GAUGES/ECT.
Timing Belt-Cosworth Timing Belt (X)
http://www.rallysportdirect.com/Cosw...rce=GoogleBase
Tires-Dunlop Dirreza Radials 235 45 R17 (X)
http://www.tirerack.com/tires/tires....omCompare1=yes
Bov-Synapse DV (X)
http://www.maperformance.com/synapse...1a.kit003.html
Wastegate-Tial 44mm V Band $375.00
http://www.customcarscentral.com/tia...all-makes.html
(1.1 bar)
Brake Lines- SS Brake Lines $119.95
http://shop.edoperformance.com/ams-s...ource=googleps
AEM Oil Temp Gauge-$150.55
http://www.maperformance.com/aem-oil...2-30-4402.html
Gauges-Aem Volts, Oil Temp & Wideband Gauges, Defi Boost, Oil Pressure, EGT (X)
MBC-Hallman in car boost controller
Control Unit-Defi Control Unit
Battery-Carbon Fiber Braille 11.5lb Battery
Coil-overs-Bc Racing Adjustable Coil Overs
Short Throw Shifter
Vms Oil Catch Can
Stainless Drilled & Slotted Rotors
Carbon Fiber Wing, HIDs & Smoked Taillights
Old Feb 6, 2012 | 08:14 AM
  #39
ChrisCarey's Avatar
Head Gasket- $68.99
FUEL SYSTEM
http://www.amazon.com/Injector-Dynamics-1000-EVO8-Fuel-Injectors/dp/B0051DS1Z2
Exhaust-AMS TBE (X)
MISC/GAUGES/ECT.
Short Throw Shifter
We will match or beat all of these prices, why not source everything from one reputable shop?
Old Feb 6, 2012 | 10:04 AM
  #40
Hey Chris these were just the cheapest prices I've found online but if you want to match those prices let me know what you carry and I would be happy to do business with you
Old Feb 6, 2012 | 01:25 PM
  #41
Already shot you over a pm to discuss your build. I haven't heard anything back? Please check out the pm and shoot me a reply to adam@maperformance.com
Old Feb 7, 2012 | 01:55 AM
  #42
@ Adam & Chris pm replied
Old Feb 15, 2012 | 07:55 AM
  #43
Your email ended up in my spam somehow. Replying to it today!
Jhurley_EvoVIII
Sep 28, 2015 04:58 AM
ddubdb3
For Sale - Cars For Sale
Aug 3, 2015 10:41 PM
APM Racing
Midwest Region
149
Jan 13, 2014 11:31 AM
SnowtaEvo
Jun 13, 2013 08:22 AM
projektevo9
63
Aug 6, 2011 07:33 PM
