Synapse dv-Boost leak test
Old Mar 15, 2012 | 02:24 PM
Evo8RLK's Avatar
So as i hooked up my Synapse bov i went to do a boost leak test, and when i got to around 12 psi everytime the bov would open up and relieve the pressure? How in the world would the bov be able to open up? It is the bigger style with port c inside.
Old Mar 15, 2012 | 03:47 PM
thedru13's Avatar
where are you hooking up your boost leak tester? take off your intake and hook it up directly to the turbo.
Old Mar 15, 2012 | 04:17 PM
Evo8RLK's Avatar
Sorry, haha i didnt specify that. Yes i removed the MAF and Intake piping. I have it connected to the turbo. the bov is hooked up with the hose coming from the UICP. That is the only hose that is hooked to it.
Old Mar 15, 2012 | 04:28 PM
deylag's Avatar
Take a picture of your engine bay. Seems you are missing the tube that is supposed to be either connected to port A or port B. Try both ports first and see if that fixes your problem.
Old Mar 15, 2012 | 04:35 PM
Evo8RLK's Avatar
I'm not home at the moment. There are suppose to be a hose connected to the ports?
Old Mar 15, 2012 | 05:27 PM
thedru13's Avatar
Yes it's a vac source. U can run ports A & B connected or one or the other to get it dialed in
Old Mar 15, 2012 | 05:28 PM
Evo8RLK's Avatar
Yes i know for running the car.. But They still need to be hooked up to it during boost leak test?
Old Mar 15, 2012 | 06:43 PM
wizzo 8's Avatar
Yes because those a & b ports help keep the bov closed under boost. Without any hoses hooked up to them the bov will leak.
Old Mar 15, 2012 | 09:33 PM
Evo8RLK's Avatar
Haha okay! had the stock bov on and i just switched it quick and didnt know about hooking hoses up! Thanks!
Old Mar 18, 2012 | 07:46 AM
Evo8RLK's Avatar
Well.. It worked BUT it leaks Around those screws on the one side. Some sort of seal has gone out?
Old Mar 18, 2012 | 09:44 AM
thedru13's Avatar
take it apart and check..
Old Mar 23, 2012 | 07:14 AM
Evo8RLK's Avatar
The seal that where the UICP hooks into the DV was ruined. replaced that and holds good.
reggiesd
20
May 11, 2018 02:24 PM
ddlopresti
Jul 28, 2015 12:57 PM
Pawl7
Mar 2, 2014 09:53 AM
free ride
10
Nov 11, 2012 04:20 PM
zenoise
Oct 31, 2012 07:23 PM
