INSTALLED: EBAY Civic Half Size Radiator!
Old Apr 25, 2012 | 01:23 PM
  #46
STLEVOIX's Avatar
I just did this swap so i figured I'd share my experience . All in all it wasn't too difficult of a swap. I ended up hitting up orielly's for the upper hose. part # is 24020, its a 1 1/4 ID very heavy duty hose. I also ended up getting two new clamps(screw down style) because the original spring clamps wouldnt work for me. On the thermostat housing, the new hose was too thick, once again very heavy duty. Then on the lower hose at the new DNA radiator I had a small drip every 5 seconds. Putting a screw down clamp on that fixed the problem.
Also ended up getting 4 feet of new overflow line which was more than enough.
Here's some pics! Enjoy
Old May 2, 2012 | 08:17 PM
  #47
ilikeppie's Avatar
So how is this working for everyone? Does anyone daily their Evo with this set-up?
Old May 3, 2012 | 09:51 AM
  #48
tim85851's Avatar
Ive been daily driving mine ever since I started this thread, NO ISSUES. NO LEAKS. NO OVERHEATING. Its good to go!
Old May 3, 2012 | 05:40 PM
  #49
ilikeppie's Avatar
very nice I am toying with the idea of doing this, I have a full size Koyorad and it is taking up a lot of room
Old May 3, 2012 | 06:38 PM
  #50
STLEVOIX's Avatar
No issues here
Old May 3, 2012 | 06:42 PM
  #51
211Ratsbud's Avatar
Wish i knew if this could handle5 minute endurance autocross runs.
Old May 3, 2012 | 06:43 PM
  #52
ilikeppie's Avatar
That would definitely test its abilities!
Old May 3, 2012 | 06:50 PM
  #53
211Ratsbud's Avatar
I think i would opt for the mirage rad first. A frontal area thing. Im also running a stock location hair dryer. But test results would be nice for consideration.
Old May 3, 2012 | 07:00 PM
  #54
korizmo's Avatar
Hmmmm this with a 145 degree thermostat to much? I'm running a giant Megan radiator that runs 2+ gallons with the 145 degree thermostat. Just looking to drop weight...
Old May 3, 2012 | 07:37 PM
  #55
Evo2372's Avatar
Not trying to be negative in anyway but you have basically reduced the cooling capacity by %50..?
How has summer been for those that have gone through it with such a reduced radiator?
Very interested as it makes way for a bigger blower...
Old May 4, 2012 | 06:59 AM
  #56
Davo's Avatar
depending on the thermostat employed, the fan may just cycle more often but with a higher cfm fan, that cycling would be reduced
Old May 4, 2012 | 08:44 AM
  #57
NODAKevo's Avatar
what size turbo and how much whp do you guys DD with this half rad?
Old May 4, 2012 | 11:30 AM
  #58
STLEVOIX's Avatar
stock 9 turbo, as far as power, not a clue
Old May 4, 2012 | 11:13 PM
  #59
tim85851's Avatar
im on a ix turbo, full bolt ons, cams, e85...probably close to 400whp...
daily drive, race...NO ISSUES.
soon to be big turbo setup...will be back with more updates...
Old May 9, 2012 | 07:16 AM
  #60
10isace's Avatar
I was excited to finish my radiator and tested it out yesterday. The temp was in the low 70's. As I was bleeding out the system, the fan would kick on, so I was happy with the ebay fan
I did notice getting ready for a test drive that the fan would kick on rather often, compared to my OEM set up.
My temp gauge on the dash showed normal coolant temps, but evoscan showed it climbing quite high. I'm normally in the 195's, but this was at 206 and climbing, 219 and finally at 226. I'm thinking I may get a better fan (slimfan or Fal) that pulls more air and/or using the race thermostat although I don't think that will help. Any suggestions?
