INSTALLED: EBAY Civic Half Size Radiator!
Old Jun 19, 2012 | 12:53 AM
  #106
evilempire76's Avatar
I'm still keeping an eye on this thread. I'll be waiting for some good ole 100+ degree days with a/c running type of data before I'll be all in on this mod.
Old Jun 19, 2012 | 08:56 AM
  #107
amsevo6975's Avatar
damn that looks good.. are you gonna trust an ebay radiator on your evo..
Old Jun 21, 2012 | 07:22 AM
  #108
tim85851's Avatar
i have just the information you need...
95+* weather, ac on blast, stop and go traffic the needle on stock temp gauge was above half, as soon as the car get moving again, the needle goes below half...
hope that information helps.
Old Jun 21, 2012 | 05:20 PM
  #109
Thanks for the update man. I might be looking to do this then soon. I'd still prefer a different option for the lower hose though if it contacts the lower mount or anything else.
Old Jun 21, 2012 | 07:22 PM
  #110
lude2evo's Avatar
Unless you buy an evo specific one the lower hose will always be near the mount. However the Evo specific ones are pricey. I havent found one that mounts opposite of the civic yet.
Old Jun 21, 2012 | 07:57 PM
  #111
ZanarkO's Avatar
how far above half? that sounds like it might have been starting to over heat.
Old Jun 22, 2012 | 02:51 AM
  #112
I'm thinking along the lines of a universal kit that you can custom fit. That is what I did with my upper radiator hose since my turbo kit was so close to the factory upper hose.
Old Jun 22, 2012 | 02:10 PM
  #113
lude2evo's Avatar
I've tired looking but most seem to be civic style
Old Jun 22, 2012 | 07:41 PM
  #114
10isace's Avatar
When I take mine out in a couple of weeks, I'm going to relocate the lower radiator hose outlet to the correct spot. That should be fairly easy. It'll be my first welding job
Old Jun 22, 2012 | 08:49 PM
  #115
BluEVOIX's Avatar
We have had some really hot weather this past couple days 95-105 F. With the AC on I did not notice any adverse change in the water temp gauge on the gauge cluster. I'll try to data log it when it gets really hot again, today was not that bad, like low 90's .
Old Jun 22, 2012 | 08:57 PM
  #116
Macaroni's Avatar
^ You still have A/C right? If so your obviously using it and is your commute in traffic or mostly highway driving?
Old Jun 27, 2012 | 08:34 PM
  #117
Chadwich's Avatar
almost done with mine and its really easy
Old Jun 28, 2012 | 02:25 AM
  #118
Please post some pics of the process if you don't mind. Good luck with the welding!
Ok any updates in regards to heat data. It's been over a 100 degrees here locally for the past couple of days.
Old Jun 28, 2012 | 06:18 AM
  #119
STLEVOIX's Avatar
107 today in Saint Louis
Old Jun 28, 2012 | 11:18 AM
  #120
Chadwich's Avatar
Just need a fan now
