6k clutch dump- am i screwed?
Old Apr 16, 2012 | 11:48 AM
ProPilot04's Avatar
Holy smokes dudes, did logic skip this tread?
1. 6k launches aren't really "good" or "bad". The Evo will handle most anything you throw at it, BUT something is going to break if you keep trying to break things. There's also NO REASON at all to launch an Evo from 6k. Ever.
2. If someone is telling you to "test" your clutch... then you're doing it wrong. A clutch is a WEAR ITEM. They WILL GO BAD. If your clutch is going bad, you'll know, because it will start to slip when it's under load. BUT! That doesn't mean you should put the car in 5th at 35mph and go WOT! If you have to go looking to see if your clutch is bad, then you're just ruining it. If it works as you need it to in the car as you drive it, then it's fine.
By comparison, I'm sure I could hook a 10,000lb trailer up to my poor Evo, and go WOT in 2nd and get my clutch to slip. But that doesn't mean the clutch is "bad".
Old May 15, 2012 | 10:39 AM
deadstockkpomp's Avatar
can you check for a slipping clutch in 4th gear also?? at low rpms then wot??
Old May 15, 2012 | 11:04 AM
mt057's Avatar
I guess I missed this one. It is fine to launch your evo from 6000+ rpm. I have done it a ton. Once you start getting the bigger turbos you have to.
Old May 15, 2012 | 04:40 PM
gpfury86's Avatar
My two step is set at 5800. People with bigger turbos are launching well over 6k!
Old May 16, 2012 | 11:19 AM
Pocketprotector's Avatar
Thanks everybody. My clutch is fine just like you all said. Thanks for the advice and sanity check. Y'all rock!
Old May 17, 2012 | 01:22 PM
stihlalive's Avatar
i drove mine hard for the first summer i had mine, i noticed mine was going bad (still is) low rpm under boost itll jump rpm
MitsuJDM
19
Nov 9, 2016 03:47 PM
Drifto
Sep 14, 2014 03:55 AM
High_PSI
141
Jun 15, 2014 05:10 PM
Harumsevo
19
Aug 10, 2013 12:26 PM
c5racr1
Oct 12, 2003 01:53 PM
