Only 8lbs boost..
Old Apr 29, 2012 | 01:02 PM
Colbyy's Avatar
Only 8lbs boost..
Only boost to like 8lbs of boost and it like surges or flutters not sure how to describe it.. I've checked all the couplers and everything. No idea. Help!
Old Apr 29, 2012 | 05:22 PM
sparky's Avatar
Post up your modlist puhleeze! Has the car always behaved like it does now? Have you made any recent changes or mods? How are you controlling boost BTW?
Old Apr 29, 2012 | 05:26 PM
ExtremeDSM's Avatar
The boost pressure reminds me of an old evo my X wife had. Her catylitic converter was all busted up inside and she was getting only 8psi of boost.
Old Apr 29, 2012 | 05:35 PM
Colbyy's Avatar
Ok so it was always fine. This winter did DNP headers, megan racing o2 housing and downpipe. I took it out went to town it was fine 20psi then coming back was only like 10lbs but at that time i didnt know my valve cover was cracked, shooting oil out. finally got a new one and all back together today and here we are
Old Apr 29, 2012 | 05:36 PM
Colbyy's Avatar
Oh and controlling boost is all stock. Also had an injen intake and catback exhaust when i bought it 3 years ago.
Old Apr 29, 2012 | 05:40 PM
Supergoslow's Avatar
is it possible the stock boost solenoid crapped out? i was told mine wouldnt allow the tuner to go past 18. im not too fond of the tuner though so i could be mistaken..
Old Apr 29, 2012 | 05:43 PM
Colbyy's Avatar
That is possible since it was working fine then just wasn't..
Old Apr 29, 2012 | 06:05 PM
Colbyy's Avatar
Happen to know the part # ?
Old Apr 30, 2012 | 04:30 AM
Colbyy's Avatar
Thinking bout trying a MBC to see if that makes a difference..
Old Apr 30, 2012 | 04:40 AM
Mikey@Spec-Ops's Avatar
Does it sound like it has an exhaust leak? I'm not really a fan of the cheaper aftermarket manifolds. They all tend to crack really bad, but you would need a bad crack for it to only boost 8psi.
Mikey
Old Apr 30, 2012 | 04:44 AM
Revo15's Avatar
Do a boost leak test, check plugs & cat!
Old Apr 30, 2012 | 06:35 AM
I believe the stock solenoid number is MN153089 but you could always hook up a gm 3 port boost solenoid there's plenty of threads on here how to.
I just used a mbc but make sure you have a boost gauge if you don't already.
Old Apr 30, 2012 | 06:39 AM
definitely make sure you have no leaks or clogged cat before jumping to any conclusions but an aftermarket boost controller won't hurt in the future
Old Apr 30, 2012 | 07:51 AM
Colbyy's Avatar
Didn't think DNP $650 was a cheap manifold. But the guy that is gonna tune it said to get a MBC before tune anyway. Ill haveto check the cat next
Old Apr 30, 2012 | 06:31 PM
Colbyy's Avatar
Made a boost leak tester tonight. But When i put air in boost gauge doesn't move. Doesn't seem like anythings happening
EvilDoesIt
Jul 13, 2023 07:36 PM
Bcon205
Aug 8, 2017 12:16 PM
Raceghost
Dec 14, 2016 12:47 PM
Johnboy1065
Mar 18, 2008 03:02 PM
TrinaBabe
88
Oct 31, 2007 03:04 PM
