EVO 9 Lean WOT
Old May 16, 2012 | 03:19 PM
tstevens's Avatar
What AFR are you seeing at WOT?
Old May 16, 2012 | 09:46 PM
crckheadjed's Avatar
still lean after fpr swap.
Old May 16, 2012 | 09:47 PM
may have spoke too soon, higher rpm's still going straight lean. Have the full log if you'd like to see more.
Old May 17, 2012 | 03:02 PM
posted log wrong.
Old May 17, 2012 | 03:05 PM
Here is the log, 3rd gear pull.
Old May 17, 2012 | 05:11 PM
So when I run the car fuel rail pressure is good, when rev'd it flucuates fine (fpr/ vacuum). But when the car is turned off the pressure gradually drops. Takes about 2 minutes slow consistant drop down to 20 psi.
Also I have the pumps hooked up to two seperate relays leaving the option to install a hobbs. Right now I jumped the relays one by one, one pump had a higher pitch to it, and the other had a lower tone to it. Not sure if that means much but could be a factor?
Old May 17, 2012 | 06:26 PM
mrfred's Avatar
How high can you crank up your fpr? If you can crank it up to say 80-90 psi, then you can test fuel flow at pressures relevant to peak boost. Run a dump line from the regulator outlet to a container of known volume (e.g., 1 liter soda bottle), and while the car isn't running, jumper the pumps one at a time while measuring how long it takes to fill the bottle. Voltage will be a little low because the car isn't running, but it should clearly indicate if there is an issue with one pump or the other.
Old May 19, 2012 | 11:07 AM
Okay so I cranked up the fpr to 95 psi and it got that high, then turned it down to 85 psi and turned the pumps on using evoscan. Disconnected one relay at a time, one pump did 85 psi, the other pump ~80-82psi. Pulled the pumps up replaced the hose sections from pump to housing and tightened them really good. Still same results.
Old May 19, 2012 | 12:01 PM
So I'm thinking one pump's output isn't as good, or it is back feed through the other pump, explaining the quick psi bleed off when the car is shut off.
Old May 19, 2012 | 12:06 PM
mrfred's Avatar
You need to watch pressure and fuel flow out the fpr. The pump that produced lower pressure probably isn't flowing.
Old May 22, 2012 | 03:31 PM
Didnt give up yet, just havent had time to get to the shop. Will keep this updated
Old May 23, 2012 | 07:29 PM
Okay so i had one brand new walbro sittin around, so i say screw it and bought another one. replaced both today and also went over the ground setup and sanded that down make sure its real good clean metal. and it was success.
LOG attached.
File Type: pdf
Old May 23, 2012 | 10:40 PM
mrfred's Avatar
LOG attached.
I don't see AFR in the log, but I''ll take your word for it.
Old May 25, 2012 | 04:04 AM
idk why it did that when i saved as a pdf, but pg 3 if you look at wideband compared to omni 4bar
FullBlown
88
Dec 30, 2018 04:06 PM
FullBlown
Oct 20, 2017 09:22 PM
surferjeff
12
Apr 21, 2015 01:38 PM
HxllxMan
Dec 8, 2008 02:20 PM
FullBlown
91
Dec 17, 2006 06:53 AM
