TOB popped off on me today
Old Jun 5, 2012 | 01:07 PM
  #31
wizzo 8's Avatar
Originally Posted by silver9mr
so if your clutch fork stopper was installed in which it was right up against the fork would this have been able to happen? i guess i dont really understant what the fork stopper is supposed to do? cause if the tob gets messed up how will the stopper do anything when the tranny has to be pulled anyways to fix it?
It shouldn't if its adjusted properly. Some people claim there's still popped off with it adjusted correctly although I don't think its physically possible. Only way is if the retainer ring broke or the groove in the tob where the ring sits gets worn out and lets go. The ring gets all bent up like in my case only when it pops off.
Old Jun 7, 2012 | 07:16 PM
  #32
wizzo 8's Avatar
Finished up last night and drove it today. Evo is back in action with the fork stopper adjusted very close to fork. Hopefully this thread gives people a heads up to what could happen if you don't have a stopper or if its adjusted incorrectly.
Old Jun 7, 2012 | 07:40 PM
  #33
ExViTermini's Avatar
Yup, just adjusted mine last nite!
Old Jun 8, 2012 | 09:23 AM
  #34
EvoIIIAj's Avatar
Congrats.. After adjusting mine a lot closer to the fork I had a successful day of racing at the local 1/8 mile and nothing happened, hopefully it stays that way!
Old Jun 8, 2012 | 09:31 AM
  #35
BoostINurI's Avatar
Ordered one for me an got my friends adjusted ....good thread ...Thanks for the info wizzo. Glad the car is ripping it up again.
Old Nov 13, 2012 | 06:38 PM
  #36
EVO KiiD's Avatar
Sorry to bring up an old thread but I'm having a hard time finding how to remove the wave ring itself, seeing as you have replaced yours you might have some insight on this. What is the best way to remove the wave ring?
Old Nov 13, 2012 | 07:01 PM
  #37
wizzo 8's Avatar
Wide flathead screwdriver and a lot of patients. You might get lucky and have it pop off first try. I fought mine for about a half hour when I replaced my clutch. I walked away for 10-15 min. Came back and magically it came of first try.
Old Nov 13, 2012 | 07:07 PM
  #38
EVO KiiD's Avatar
Thanks sir!
Old Nov 13, 2012 | 07:35 PM
  #39
Turbo01s2k's Avatar
The easiest way to get it to pop is to move the fork with your opposite hand, to release "pressure" off it, it pops very easily that way.
Old Nov 13, 2012 | 10:29 PM
  #40
icmanevo's Avatar
Glad this thread was brought back... Ive only been on here about six months and mine needed adj really bad. Thanks. I pulled the tranny once and I don't look forward to doing that again.
Old Nov 14, 2012 | 10:34 PM
  #41
EVO KiiD's Avatar
So there may be some confusion, so to clear things up here is the pic of the piece I'm talking about the wave ring. It's the spring clip piece in between the TOB and the pressure plate, I attached a pic of it circled on the Exedy twin disc from STM and a pic of the wave ring itself from STM, hope this clears things up. The TOB was a pain only because the engine was seized up but I got that off no prob but that was not my concern, that wave ring in the pics was the focus, I just pried it off by hand and it came off immediately and the new one will pop right in, very easy to do with the clutch fully exposed. FYI to all "Please get a clutch fork stop to prevent damage to this wave ring as you have to drop the trans to replace the wave ring not fun for something so simple" thanks for responding guys!
Old Nov 16, 2012 | 05:27 AM
  #42
Liqquid's Avatar
Just to share some info, I also had broken a wedge collar (a.k.a the infamous clutch clip) on my exedy twin, and had to go through all of this. Afterwards, I adjusted it tight as you guys are discussing, credit card, to actually setting it with feeler gauges. Since then, indeed it has not popped off, however, I have not 'no-lift' shifted the car since popping the clip off the first time, which is what originally happened.
The next issue came about after the DSM shootout, when I let the clutch out too slow on a couple passes from the launch and seem to have took off some material I had to adjust the pedal to get the engagement height correct again, and then realized the clutch was slipping under WOT. I discovered my clearances on the fork stop were no longer there and it was touching, causing the issue. I readjusted and everything was fine for a bit, then it started slipping again so I went back, checked, and sure enough no good. I gave it a little bit more, back to a credit card thickness, and made sure the stopper was good n tight. After that everything seems to be back on track.
Just wanted to share that in case anyone runs across any slipping afterwards, be observant and don't hesitate to check the stopper often.
Old Nov 16, 2012 | 06:03 PM
  #43
fouringEVO's Avatar
I have the STM clutch fork stop adjusted to credit card clearences and never had a problem, very great product
Old Jan 7, 2013 | 11:45 AM
  #44
thomas.featsent's Avatar
Quick question when installing the clutch do you attach the clip to the clutch or to the TOB ?
Old Jan 7, 2013 | 05:25 PM
  #45
wizzo 8's Avatar
Clutch. The tob snaps into it and locks in
Ginglingston11
Aug 18, 2011 05:10 PM
EVODreams
Jan 9, 2011 07:32 PM
AtticusDemon
18
Oct 10, 2009 08:32 PM
rgar
Aug 4, 2009 08:38 AM
EVOLV3D
May 21, 2009 06:46 AM
