Trans fluid change help
Old Jun 22, 2012 | 10:23 AM
ragyan03's Avatar
Doing a tranny and TC fluid change on an 03 evo 8 gsr with about 120k miles and I have some question..
1. For the TC I went to mitsu and got the ATF SP-lll oil..2qts is that enough and is this the right fluid..It didn't have any viscosity number on it so I got confused
2. I am just sticking to OEM and was wondering what the oil is called and how much would I need..the guy at mitsu didn't seem like he knew what he was looking for..so if someone could get me the name, viscosity, and how much I need that'd be great
3. Does my evo have the LSD tranny, ayc, or acd? I know my evo was the first year in the US..and I just recently purchased this evo which is my first evo..
drive train is completely stock..thanks
Old Jun 22, 2012 | 10:42 AM
gsrboi80's Avatar
DO NOT PUT THAT FLUID IN YOUR TC
Diaqueen 90wt LSD in TC and Rear Diff is what you want
See this sticky thread
https://www.evolutionm.net/forums/ev...uantities.html
Old Jun 22, 2012 | 10:45 AM
fantrman's Avatar
Doesn't sound like the parts guy knows his stuff. Use ONLY Mitsubishi Diagreen LSD Gear Oil 90W for the TC, nothing else.
As far as I know, non-RS 03 Evos did not have LSD, AYC or ACD.
Old Jun 22, 2012 | 10:47 AM
ragyan03's Avatar
Ok I'll return that right away and make sure to get diaqueen! Thanks for the help
Old Jun 22, 2012 | 10:50 AM
fantrman's Avatar
Good you asked. That likely saved you a re-build in a few weeks - no joke.
Also, be sure to read and follow the How To for TC oil change (fill, drive and fill again).
Old Jun 22, 2012 | 11:07 AM
Evoardo IX's Avatar
The ATF SPIII is for ACD equipped evos, it's the fluid that goes in the ACD pump's reservoir, you have no ACD, so you do not need that fluid.
BillCosbysPudding
Mitsubishi TC-SST Discussion
73
May 11, 2017 09:12 AM
My03evo
Apr 20, 2011 10:26 PM
Nastynine
15
Oct 3, 2009 10:14 PM
Spunkysandoval
Jul 25, 2009 06:15 AM
CanadianEvo
13
Aug 13, 2008 08:30 PM
