just did drivetrain fluids and..
Old Jul 6, 2012 | 01:53 PM
  #31
fireroasted's Avatar
Originally Posted by evodriver49
you dont think overfilling might possibly cause the seals to wear from too much pressure? just a theory !
Overfilling slightly is recommended by most of the evo trans shop specialists. One of the reasons that likely became the norm is that most common damage is caused by under filling and hard driving.
Also, people get real touchy about their fluid choice. EVeryone comes up with cocktails they swear is the end all be all. Even I had one of those complex mixtures back in my WRX days. Essentially it doesn't apply to the OP though. At least I believe, based on lots of reading and discussions that stock fluid is best for non track duty Evos. The characteristics are best for all around driving and some canyon carving. Once you move to drag or track abuse, stepping up to the engineered oils can help reduce stress on the metal that you are causing by violent shifts or extreme high continuous heat. (metal doesn't like either).
Again, most important is to change the stuff frequently.
Old Jul 6, 2012 | 02:08 PM
  #32
evodriver49's Avatar
thanks for clearing up man! the oem tranny fluid didnt help my syncro problem therefore once i found redline mt85/90 which "fixed" it, i always swore by their product. But your explanation and reasoning are all on point!
Old Jul 6, 2012 | 08:04 PM
  #33
barneyb's Avatar
Originally Posted by deadstockkpomp
Im lucky enough to have access to a lift, would you say open the fill plug and if it leaks its good to go
Yes
zeero260
May 20, 2025 05:50 AM
jakgal04
Oct 20, 2015 06:23 AM
Evol Darwin
Nov 28, 2014 12:48 AM
ElectrIX Blue
Mar 21, 2014 06:51 PM
SpyderTB
Apr 23, 2008 09:33 PM
