Compression test on a built motor??
Old Aug 27, 2013 | 01:51 PM
jspecteggy's Avatar
Could also be the tester you're using is off by a bit and reading a little high if its a fully stock motor for sure?
Old Aug 27, 2013 | 02:07 PM
Cmax's Avatar
I bought the car from the original owner at 17k miles. He never said anything about having drop ins put in or having the motor built, but it's always a possibility that he did and just didn't tell me. I personally have never pulled the head or oil pan. I'm going to check tonight and see if the stock pistons are in there or not.
And as far as the compression tester goes, it is used on evos a couple times a week. It hasn't shown anything higher than 180-185 on a stock block. This is why is it so odd that we're getting 195-200.
Old Aug 27, 2013 | 05:08 PM
jspecteggy's Avatar
Let us know what you find, I'm curious..
Old Aug 27, 2013 | 07:58 PM
Cmax's Avatar
Looks to me like stock pistons in there. I couldn't verify the 63dt, but it had the cast circle in the center like a stock piston.
Old Aug 27, 2013 | 08:20 PM
batty200's Avatar
Verify the Cam timing and Crank timing. A timing belt that is off can cause higher than normal compression numbers. If all is well you just have a very healthy engine. Mine was always a little higher than average too.
Old Aug 27, 2013 | 10:49 PM
Cmax's Avatar
I'll check that out tomorrow. Didn't know that could cause that. Thanks. Will update tomorrow.
Old Aug 27, 2013 | 11:20 PM
evoIXcencal83's Avatar
Just did a compression test and plug change today. 173, 175, 171, 170...I was happy with the results. Stock block 112,000 miles on 23 psi.
mike_89
Jan 11, 2015 06:32 PM
dsmchiz
Aug 26, 2014 07:54 AM
brakeboost980
Jul 15, 2012 06:37 PM
AKEVOIX
Apr 27, 2009 06:41 PM
project_skyline
22
Feb 17, 2009 09:08 PM
