Anybody elses car die in 4th?
Old Jan 29, 2004 | 09:37 AM
UFO's Avatar
UFO
My 1st trip to the track I ran a 13.5 @ 100 (99.6 actually, lowest run was 98) with my stock car. I noticed at the time that going into 4th the car would stumble slightly. It wasn't fuel cut because it wasn't that severe, it was more like the engine just 'missed' for a split second. I was running 2.0 60' times (it was very very cold) and 80 - 82 MPH in the 1/8. Looking at my slips I knew the 1/4 trap should have been higher, but didn't really care. A few weeks ago I got DynoFlashed & added a MBC. Off to the track I went thinking I would kick ***. I didn't. The car ran 85 MPH in the 1/8 (3.5 MPH average improvement) yet my best was 13.1 @ 101. Again, the car was stumbling going into 4th. It's never really bothered me because, to be honest, I don't wind 3rd out to redline and shift hard into 4th on very many occasions, until I did so this morning, and now it's bothering me . Any ideas why this is happening?
Please spare me the 'Evo ain't a drag car' comments though because the same exact symptoms happen on the street. Also, it's not the reflash either because the car had the same symptoms before.
Old Jan 29, 2004 | 09:41 AM
nebolic's Avatar
can you state what other mods you have, or do you have have a MBC and flash.... however if you have a flash, why would you still need a MBC?
Maybe if the car is stumbling is because you're hitting boost spike at the fuel cut range??? not sure.. just throwing out ideas.
Old Jan 29, 2004 | 09:51 AM
UFO's Avatar
UFO
Buschur filter, DynoFlash, and Perrin MBC is all I have. Like I said though, it did the exact same thing when stock. I have the MB because I wasnted to have the ability to turn the boost up (I run 20 PSI)
Old Jan 29, 2004 | 12:47 PM
bluevilevo8's Avatar
Is it missing? If so, gap your plugs tighter.
Old Jan 29, 2004 | 12:58 PM
UFO's Avatar
UFO
It feels like it's missing but I'm not sure if it is - it's odd. What should the plugs be gapped at, .035?
Old Jan 29, 2004 | 04:38 PM
NO!!!! Trust me and gap them between .025-.027
Anything gapped over .029 will miss at your boost levels. Also, I STRONGLY recommend you switch to denso IW24's. They are 1 heat range cooler helping to quell detonation, and are a better plug.
Old Jan 29, 2004 | 04:42 PM
Creamo3's Avatar
I agree to check to see if your plugs are gapped correctly or to see if any of them are fouled
Old Jan 29, 2004 | 04:49 PM
Alfriedesq's Avatar
You need a new set of plugs and gap them 24 - see if that removes this issue
Also - what psi are you running ? Do you have a fuel pump upgrade?
Old Jan 29, 2004 | 04:51 PM
Alfriedesq's Avatar
Re: Anybody elses car die in 4th?
BTW - my through the mail reflash is quoted at 12 - 15 whp PEAK gain - the main part you see on the strip. a 3 mph gain in the 1/8th shows me you got the rigtht amount of gain on the flash
The main differnce with the through the mail flash is in the broader and flatter trq curve and smoother feel
Old Jan 29, 2004 | 04:59 PM
Don't mean to hijack this thread, but...
Al, are there any other alternatives to the walboro pump (I don't want any noise)? I have heard of people using the pump off a supra tt. Do you know what kind of work would be involved in going that route, or do you have any other suggestions?
Thanks
-Dave
Old Jan 29, 2004 | 05:40 PM
UFO's Avatar
UFO
Re: Re: Anybody elses car die in 4th?
Yeah, like I said before it's not the flash. I was looking at my timeslips last night and only then realised the higher MPH at the 1/8 mark. As I have said to you before: I couldn't be happier with the flash, it rocks .
I'll go buy some plugs this weekend and swap them out and report back with the results. Thanks for the suggestions.
Old Jan 29, 2004 | 05:58 PM
Alfriedesq's Avatar
Thanks
-Dave
The walboro is nice becuase it pops righgt in and is cheap - there are other pop in alternatives
The supra / cosmos pumps are not pop in - it requires some fabrication and modification
I prefer the pop in method
StreetThisEvo
Oct 28, 2012 05:45 AM
AlwaysinBoost
Nov 26, 2006 06:43 PM
Warrtalon
May 16, 2005 07:26 PM
RnR Racing
12
Sep 15, 2003 12:22 PM
EVOlunchbox
Apr 14, 2003 12:51 AM
