Need a timing belt, and on a budget? Here's how!
Old Oct 12, 2015 | 06:47 PM
  #121
azboost92's Avatar
Looks like I wont have to fork over a grand now! thanks
Old Oct 17, 2015 | 08:16 PM
  #122
budo83's Avatar
Hey guys i purchased my second Evo few weeks ago and need some work done on it anybody close to Bowling Green Kentucky that is willing to give me some advice and possibly do some good for me it is a 2003 model with 93000 miles please let me know thanks in advance
Old Oct 26, 2015 | 10:25 PM
  #123
Seancc1988's Avatar
Great info thanks a ton!
Old Nov 20, 2015 | 08:59 AM
  #124
cts4g63's Avatar
At what mileage does Mitsubishi suggest you replace your timing belt/water pump?
Old Nov 20, 2015 | 11:29 AM
  #125
zenki-s13's Avatar
timing belt every 60k along with driveline fluids.
water pump I don't think has an interval. But you should replace it at the same time to save hassle.
Old Nov 30, 2015 | 04:09 PM
  #126
danfalcas's Avatar
Links 2015
AMAZON LINKS 225$
Old Dec 11, 2015 | 08:25 AM
  #127
Jeepyedo's Avatar
This is great info. Thanks
Old Dec 15, 2015 | 08:45 PM
  #128
wazmunstr's Avatar
No problem guys! Glad I contributed this community
Old Feb 18, 2016 | 08:56 AM
  #129
danfalcas's Avatar
Hi guys,
I recently did all of this to my baby, and it works like a charm. The only thing is that the Gates Water Pump - 42577 didnot worked on my 7.
Does someone knows which water pump can I buy for my 7? Appreciate the help.
Thanks
Old Feb 18, 2016 | 08:57 AM
  #130
danfalcas's Avatar
60K / 120K
Old Feb 18, 2016 | 10:45 AM
  #131
cts4g63's Avatar
Originally Posted by danfalcas
60K / 120K
Thank you guys! I am at 47k currently so I will be doing timing belt/water pump at 60k.
Old Feb 26, 2016 | 04:12 PM
  #132
Pal215's Avatar
Are these parts even slightly different than oem parts? Would it be wise to use these parts on a high horsepower build or is this more for low to midrange power evos?
-pal215
Old Mar 18, 2016 | 01:48 PM
  #133
jreynolds.lti's Avatar
So I am unable to do this job on my own right now due to injuries and the dealer wants to sell me the balancer belt tensioner part number MD352473 and that part isn't listed here. Is this a part that needs to be replaced at 60k on an 03 Evo?
Old Mar 27, 2016 | 09:11 AM
  #134
CDrinkH2O's Avatar
Yep - balance shaft belt and tensioner must be replaced. If that thing breaks it will create mayhem by wrapping around the cam belt, smashing the CAS and trigger wheel, and possibly causing your camshaft pulleys to skip time, wiping out your valve train in the process.
Old Apr 20, 2016 | 03:23 PM
  #135
arkangel13's Avatar
Hi guys, proud Evo V owner here
Does anyone know in the practice if evo V pump is the same as evo 8?
I have different part numbers:
CP9A (Evo V/VI) : MD975913
CT9A (Evo VII-IX) : MD977311
But for both, the replacement number is 1300A069
So techincally, they are the same. Can someone confirm?
I have not ordered the kit because of this detail
Thanks to anyone who can help
