Backfiring Evo 8
Old Feb 2, 2004 | 09:25 AM
AustinEvo8's Avatar
Backfiring Evo 8
My evo keeps backfiring, but only at WOT in 3rd Gear. Really, this is the only time it happens. I don't have fuel management, but I do have a full 3" turbo back with cat delete.
What's going on? Is this damaging the turbo? It is very loud and there is a huge puff of black smoke (40x40) cloud, oh yea...burnt the back have of bumper already, and yea it's burnt!
Please advise.
Old Feb 2, 2004 | 09:28 AM
camdog17's Avatar
Damn, good luck with that! Wish I could help! I've seen that happen on several cars lately....
Old Feb 2, 2004 | 09:31 AM
Secret Chimp's Avatar
I was under the impression that the cat burns off any fuel left over from the combustion process. if this is truely how it works, then your stock (and overly rich) mix could build up enough fuel in the exhaust to cause a bang....
But this is just my semi-knowledgeable guess.
SC~
Ryanmcd3's Avatar
In Timeout
Re: Backfiring Evo 8
Run a cat. It will fix that problem.
Please advise.
Old Feb 2, 2004 | 09:33 AM
IgotaWhiteOne's Avatar
buy an afc and lean it out
Ryanmcd3's Avatar
In Timeout
You are right. I had a TT Rx-7 without a cat and the flames and backfire were cool until the bumper discolored, smelled like **** and people thought I was shooting at them because the backfire is so loud.
SC~
Old Feb 2, 2004 | 09:40 AM
sneaky8's Avatar
Q) how bad could a back fire be with downpipe, test pipe, n full exhaust????
Old Feb 2, 2004 | 09:47 AM
Jamdown's Avatar
Hey AustinEvo8, do you have an aftermarket BOV? I am surprised that an otherwise stock car would be so damn rich!
Old Feb 2, 2004 | 10:36 AM
GotBoost25psi's Avatar
my car backfired in every gear at 5500rpm to 7000rpm just with the exhaust, and i also added a bov and it didnt change (better or worst)
Old Feb 2, 2004 | 03:22 PM
Serge03's Avatar
your car is backfiring because it is running too rich, and the unburnt fuel is being burnt off in your exhaust. The thing is though, running catless also tends to make a car shoot flames as well. Getting some sort of fuel management is going to help out your situation a lot... you may still have a problem running catless, but the occurence will decrease once you lean out a bit.
Old Feb 2, 2004 | 03:30 PM
AustinEvo8's Avatar
Cool thanks for the info...BTW I do have a Greddy BOV recirc with a Type-R spring.
Old Feb 2, 2004 | 03:49 PM
MrBonus's Avatar
I'll bet you get a cool flame shooting out your tailpipe on hard shifts too.
Old Feb 17, 2004 | 01:16 PM
AustinEvo8's Avatar
it chuffs 4 ft flame *****...burnt the back bumper cover.
Old Feb 17, 2004 | 04:14 PM
timzcat's Avatar
A side note, make sure your exhaust does not have any leaks.
Even a small leak will cause oxygen rich air to enter the exhaust midstream and will ignite the unburnt fuel like a SOB. I've seem muffler cases blown apart from such a case.
Racco
24
Mar 29, 2010 03:19 PM
italianevo88
15
Oct 2, 2009 02:16 PM
BlueEvolution
Jan 14, 2008 11:26 PM
evo82003
Nov 3, 2004 10:05 AM
1QWKEVO
Mar 28, 2004 10:25 PM
