anti freeze question
Old Oct 2, 2012 | 06:53 PM
winkdogydog101's Avatar
Ok a few things whats the best way to drain all the coolant and flush it with the evo 8?
I have to put in a new water pump and timing belt so i fidgured the time was perfect for changing the anti freeze
first I live in AZ where our winters get into the 40's I guess maybe once in a while freezing but was wondering if I could get away with wetter water and distilled water?
I was thinking 2-3 bottles of wetter water and how ever much distilled water it takes?
would you guys suggest adding antifreeze like 50/50 or no?
if so whats better to run normal or dexacool?
thanks for your guys help
Old Oct 2, 2012 | 08:15 PM
SPANKED's Avatar
Definitely don't use Dexacool!!! Heard mixed reviews about water wetter. Can't go wrong with 50/50.
Old Oct 2, 2012 | 08:42 PM
damn really ran wetter water and dexacool 20/80 last car but you think I could get away with 30/70 in az weather?
Old Oct 2, 2012 | 08:48 PM
adriano_917's Avatar
Dexcool! Just use Prestone 50/50, theres no need For water wetter. Why 30/70 ?
Old Oct 2, 2012 | 08:53 PM
RallySport Direct's Avatar
Silver Sponsor
I have personally ran Distilled water and 1 bottle of water wetter in my car during the summer and never had any heating issues
Great link with instructions on How to: Radiator fluid flush & coolant flush.
https://www.evolutionm.net/forums/ev...ant-flush.html
Hope that help you out
Thanks,
Dallin
Old Oct 2, 2012 | 09:05 PM
I run Prestone 50/50 in Texas heat(110*f)and the needle stays a tad before half.
Old Oct 3, 2012 | 05:47 PM
and a bottle of wetter water?
Old Oct 3, 2012 | 05:52 PM
n2oiroc's Avatar
id do at least 25% coolant for lubricity and corrosion protection. and yes on the water wetter, its good stuff.
Old Oct 3, 2012 | 07:01 PM
Topher86's Avatar
50/50 for sure.
Old Oct 3, 2012 | 07:18 PM
just one bottle or more then one?
Old Oct 3, 2012 | 07:29 PM
nytalonTSi's Avatar
I go with prestone 50/50. Noticed some other coolants still use a amount of silicate.
Old Oct 3, 2012 | 10:22 PM
Silver Sponsor
I only ran one bottle and this was for a short period of time from Jun-Sept. Yes running a little coolant in the system would be ideal to help with lubrication, but on most tracks they don't want any coolant in the cars to help with mess clean up if something where to happen. There where 5 events in this time frame and I didn't want to drain coolant all the times so I ran the water with water wetter. I am sure I could used 2, but I just had one sitting in my garage at the time and used it
I would not say that this is a good long term solution just saying what I have tried and I have seen more rust in my other motor that has always had coolant in it than my Evo that ran water though it Less miles on the motor, but still the same year car/ motor
Thanks,
Dallin
Old Oct 4, 2012 | 06:09 PM
Randal's Avatar
Guest
I uses Peak extended coolant 50/50, what I do is drain radiator them flush it with a gallon and a half of distiller water.
Old Oct 9, 2012 | 03:58 PM
Frew's Avatar
**** this guy, dont answer any of his questions, hes a scammer and has scammed people on cobaltss.net, here, redlineforums, etc
kyoo
220
Dec 11, 2018 01:32 PM
H Jensen
11
Oct 27, 2012 07:02 AM
EVIL_EV0
Jun 6, 2011 06:55 AM
MR White
31
Sep 29, 2010 05:49 PM
dansxr2
Sep 24, 2009 09:05 AM
