Squash Performance Evo 7/8/9 Fuel System - tester needed ASAP
personally, i think if you plan on running over 30 psi boost and/or 550 whp on e85, run a -6 feed and use the stock feed line as a return.
Fred,
I spoke to the engineer from Walbro @ SEMA... he went into great detail about how the OG 255 HP pumps were not meant to be used in Ethanol and about 6 reasons why they'll fail prematurely. That being said... they HAVE been used in ethanol by about everybody with great success, but I think I'll be going to their Ethanol 400lph pumps.
I agree, but the downside to the E85 walbro pumps is that you have to get a new FPR, mod the siphon, and change the high voltage crossover for them to work as intended... Not saying that is a bad thing, but we all know how everyone wants to go fast on the cheap around here...
Correct the pump will "work" without the rewire, however you loose a lot of the pumps capability... if it is rewired, it needs to have the siphon drilled and an adjustable FPR or you may be able to sneak past it with adjusting the high voltage crossover point, but I would recommend an AFPR...
the squash setup has its own return venturi, nothing to drill. and the harness is all good. only thing is the fpr. he will have a solution though, a pwm controller that you can even use to run a returnless setup if you want.
Andy
As far as overrunning the stock FPR with one of those pumps, it's going to be close. I haven't actually tested it against the stock FPR yet. The stock return line is really small, but it should handle the flow of one pump at full tilt, barely.
Andy
Pricing has been posted: https://www.evolutionm.net/forums/ev...l#post10541335
