Squash Performance Evo 7/8/9 Fuel System - tester needed ASAP
Has anyone tested these yet?
I currently have a FULL BLOWN DP Setup and I have nothing but issues with it.. (leaks through the wiring).
Currently looking for a DP solution to replace it...
No leaks at all, pulls from the other tank perfect.
Andy made sure that its worth the cash.
The W450 is longer than a W255, but it can fit without a spacer. I can't recall how they designed the pump carrier, but if they had used an o-ring style connection like stock between the pump and pump carrier, a spacer plate would not be needed.
I know that Andy had some issues with the first units and the pumps being down to far. I believe he mounted them higher after that.
To my recollection the pump would need to be moved higher. I think the PIA with that is just shortening the fuel line from the top of the pump to the hanger. The bracket can be loosened and slide the pump up a bit.
Correct me if I am wrong but that is what I remember of the assembly.
