Still Whining
Old Oct 21, 2012 | 05:58 PM
WHTEVO's Avatar
/\ Did you start the car while the belt was off to confirm it is actually one of the accessories causing the noise?
Aaron
Old Oct 29, 2012 | 09:58 PM
superkizuna's Avatar
No I haven't tried that yet. That will be next. The car will start with the serpentine belt off? Will a tensioner that is too tight whine like that?
Old Nov 4, 2012 | 08:13 AM
Well I just left the auto shop and it is indeed something going on with the power steering. We took the cam cover off and everything in there was fine. I don't understand how the power steering is acting up when I just bought this god damn part!
Old Nov 4, 2012 | 02:16 PM
fel222's Avatar
I have the exact same noise, i have no more ac compresser, also i started the car without the belt and there was no more whine, the thing is i also installed a new ps pump, maybe they need to get bleeded???????
Old Nov 4, 2012 | 04:14 PM
90zcrex's Avatar
Sounds like the power steering pump. Remove the serpentine belt and see if the noise goes away. If it does thats most likely your noise.
New pumps go bad all of the time. Also make sure you bleed the pump really good and don't run it dry, and use the correct fluid. All of these will cause the pump to quickly fail.
Old Nov 7, 2012 | 04:08 AM
Hey, thanks for the help all. I'm having the original power steering rebuilt. If that suckers gets slapped on and I'm still whining then I'm going to go crazy.
Old Mar 3, 2013 | 07:20 AM
Okay..... figured I would provide an update. I'll put it like this, if your evo is whining be sure and try the idler pulley first! I went through so much stress cruising around with the whine that I didn't want to drive the car. I was jumping in my wife's corrola, no ****.
I went through 2 power steering pumps! All in all it was a 40 dollar accessory belt idler pulley. I have a youtube detailing the issue/sound. Thanks for reading. HTH
m.youtube.com/watch?v=_gyeJy9D7kI
Old Mar 4, 2013 | 04:45 AM
fel222's Avatar
Thanks for sharing, buying one right now
Old Mar 5, 2013 | 05:23 AM
Cool, let me know what happens and if that is the fix for you or not. Trust me a less scrupulous mechanic will use that noise to reel in your dough. I had 2 try to charge me for all kinds of crap they 'said' was the problem.
Old Oct 24, 2013 | 10:42 AM
HDA's Avatar
HDA
Italian license plate FTW!
TreatsIX
Jun 6, 2015 06:58 AM
evo_k
Pacific Northwest
18
Jan 10, 2015 07:56 PM
nwa7265
Mar 27, 2014 09:22 PM
simplecomplex
Lancer Troubleshooting
May 20, 2010 09:09 AM
94AWDcoupe
54
Nov 24, 2009 03:13 PM
