HKS 272 cams?
Old Oct 17, 2012 | 08:50 AM
Ev0ikon's Avatar
Originally Posted by akqowns
hm.. so if I lower the idle, and the car makes lope sound, does that mean it has cams?
or stock cams could make lope sound as well?
Not sure if I woul call it "loping" sound, but yes changing the target idle will change the sound regardless of what cams are in it.
Old Oct 17, 2012 | 12:28 PM
akqowns's Avatar
oh.. so there's no way I can figure out if it has cams installed unless open the valve cover?
Old Oct 17, 2012 | 12:46 PM
Ev0ikon's Avatar
Correct!
Old Oct 17, 2012 | 02:12 PM
akqowns's Avatar
Originally Posted by Ev0ikon
Correct!
alrighty, I might try to open the valve cover soon hopefully.
Thanks for help
Old Oct 17, 2012 | 02:25 PM
Ev0ikon's Avatar
Thanks for help
No prob!
When you put the cover back, torque down just as indicated in the service manual. Too tight it would more likely cause leaks. If it has been a long while it may be a good idea for you to replace the gasket set, too.
Old Oct 17, 2012 | 04:37 PM
ETS Michael's Avatar
I would open it up and take a look. The HKS are mild cams compared to the GSC and Kelfords though.
Michael
Domengg Domino
Dec 1, 2016 12:07 PM
supafly_mx
Jun 10, 2015 08:55 AM
Xtsy
Oct 25, 2012 04:42 PM
TheeVOoNE
35
Oct 18, 2010 07:58 AM
EvolutionTime
15
Mar 21, 2010 07:08 AM
