exedy twin. stabbing evo tranny first-timer
Old Oct 31, 2012 | 02:45 AM
chad99evo's Avatar
this is my first trans r&r on an evo. it has an exedy twin. i removed it with care so the springs and everything stayed properly stacked on top of the tob, but the circlip remained loose just inside the pressure plate/fingers. what do i do with it?
i couldnt find a write-up with this in it. i would not like to screw up something so simple in respect to how much work this is, as this is a bit of a pita on my garage floor by myself.
Old Oct 31, 2012 | 07:13 AM
bubba17's Avatar
Are you talking about the wave ring clip? If so you more than likley broke it/mangled it getting it off. So order a new one.
Old Oct 31, 2012 | 07:25 AM
cfdfireman1's Avatar
If it looks like this you're good.
Old Oct 31, 2012 | 07:34 AM
chad99evo's Avatar
it fell inside. i fished it out last night , it is in great shape. a friend called me and told me how to put it back in .
Old Nov 1, 2012 | 07:17 AM
Personally I would pull the clutch apart and check the thickness of the friction plates. Now may be the time to replace them. ;-)
Old Nov 6, 2012 | 02:08 AM
chad99evo's Avatar
Thanks . Its a new clutch. Only 650 miles. I pulled my trans out as I rebuilt one I wanted to install.
Old Jan 7, 2013 | 11:33 AM
thomas.featsent's Avatar
When you installed the clutch did you install it with the wave clip in the clutch or on the TOB
manthny18
Feb 19, 2016 10:16 PM
powerdriver
Mar 8, 2013 12:53 PM
bbyevo8u
Jul 15, 2012 11:41 PM
4g63evoeight
Sep 3, 2011 08:03 AM
k270kmh
Jul 23, 2009 07:58 PM
