2.4L swap
Old Nov 12, 2012 | 07:15 AM
300zxhks's Avatar
2.4L swap
What all is needed for a 2.4L swap? Can a 4G63 crank be used in the 4G64 with custom rods and pistons? What kind of comp ratios should be used? And do oil squirters need to be machined into the block? I have a 2.4l block already that needs a crank, previous owner did not build the 2.4l when he swapped it and I found out the hard way.
Thanks,
-Mike
Old Nov 12, 2012 | 07:37 AM
jmcmill3's Avatar
Thanks,
-Mike
before people start flaming you, you should search.. the answers are definitely in here
1. yes the 88MM crank from a 63 can be used
2. comp ratio.. = your choice
3. oil squirters = not mandatory
Old Nov 12, 2012 | 08:35 AM
300zxhks's Avatar
I was on my phone and could not search. Im home now and can search. Thanks though
purpledranktown
Lancer Engine Tech
Mar 10, 2014 05:33 PM
rd122481
May 9, 2013 01:23 AM
bigleadfoot
Sep 18, 2008 08:20 AM
Evo3GEclipse
Jun 14, 2007 03:10 PM
PiNG
AEM EMS
Oct 23, 2006 12:04 AM
