Removing transmission counterweight
Old Nov 23, 2012 | 12:37 PM
Rom's Avatar
Rom
Hi all,
So I have an Evo MR and just installed the ETS UICP kit. Unfortunately, however, since the MR has the 6-speed transmission it also has a counterweight that sits on top of the transmission. When I shift in to reverse, the counterweight raises up and hits the UICP pipe!
I spoke with ETS and they said that this is a known issue and that I could just remove the counterweight and it would be fine. Before I do that though, I had a couple of questions:
1) Does anyone know what that counterweight really does? Any negative shifting effects from removing it?
2) If I remove it will I need any replacement bolts or anything? Not sure if they uses one long bolt that goes through the counterweight all the way down to the transmission, and thus I would need a shorter bolt to re-attach the shifter cable assembly.
Thanks in advance for the help!
S.
Old Nov 26, 2012 | 12:59 PM
BURNALL_4's Avatar
If they said it was fin to remove it.... I'll agree with them.
dafunk630
Oct 16, 2009 10:50 PM
hytek369
Aug 27, 2008 11:28 PM
xanderracing
Lancer Troubleshooting
Nov 11, 2007 04:43 PM
Itsmeeeugene
Aug 28, 2006 09:00 PM
EvilBlueEvo8
Feb 8, 2005 12:49 PM
