Evo 9 stalls when making a turn on highway
Old Nov 25, 2012 | 05:21 PM
Mr2fine's Avatar
I have an evo 9 with a 2.4 built motor. The tranny was rebuilt with a longer 4th gear and an act unsprung 6 puck clutch and fidanza flywheel was installed with it. Sometimes when I am exiting off a highway where there is a sharp turn, the car will stall when I downshift and even when I am in neutral while making the turn. I have to give it some gas and the car will come back on while I am turning. I do not have to turn the key or anything where it stalls. The only way it wont stall is lets say Im on 3rd gear and I stay on that gear the whole time but sometimes I have to brake and downshift if the turn is sharp. Also, I have the clutch chatter that only goes away when my foot is on the clutch and when I get off 1st gear, there is a loud chalk board screeching sound. Does the stalling problem have anything to do with the tranny? I forgot to mention that it has ac delete, the compressor and all ac lines are taken off. There is a shorter belt that bypasses everything. So sometimes when Im going slow or are in neutral, the wheel is hard to turn because there is no power steering. Could this be the cause of the problem?
Old Nov 25, 2012 | 07:10 PM
TheReal94_tsi's Avatar
Are you getting into super low rpm's when it does it?
Old Nov 25, 2012 | 08:01 PM
cmspaz's Avatar
Mod list?
Is your diverter valve dumped to atmosphere?
Old Nov 25, 2012 | 08:59 PM
Mr2fine's Avatar
I would shift it 2-3 rpms and even if I put it in neutral and take the turn, the car should not stall but it does. My mods are:
Turbo Trix built Long Rod 2.4
Manely I beams
weisco pistons
balance shaft delete
machined o-ring head
arp main
arp head studs
port/polished head with 1mm oversized titanium valves
supertech springs
supertech retainers
gsc s1 cams 280/272
adjustable intake cam gear
kiggly racing plate for oil pressure restriction
injen upper intercooler pipe
injen intake with k&n filter
turbo smart blow off valve
ams lower intercooler pipe
turbo xs intercooler
turbo xs turbo back exhaust
custom dump 02 housing
evo 8 turbo
custom oil catch can
hallman pro boost controller
magnus intake manifold
megan racing exhaust manifold
720 fuel injectors
255 walboro fuel pump
battery relocation
a/c delete
Rebuilt Transmission with Evo 8 4th gear
fidanza flywheel
act 6 puck unsprung clutch
Old Nov 25, 2012 | 09:02 PM
High_PSI's Avatar
Ahhhh turbo tricks............
ScoobehDoo
Aug 28, 2013 04:03 PM
Evo_IX_Guy
23
Dec 5, 2012 12:19 AM
deadstockkpomp
Jul 16, 2012 07:41 PM
alpix715
Aug 30, 2010 03:13 AM
hotredevo
Jul 29, 2010 06:54 AM
