Evo 9 GSR & TTR Built 2.3L Oil Consumption
Old Jul 1, 2013 | 12:29 PM
  #106
bbong's Avatar
Originally Posted by Joshthree6three
If you have oil pooling on the tops of the pistons, I doubt it is the turbo. What was done to the head before/during/after the motor swaps. Could be your valves guides leaking. That would explain oil on the pistons after two replacement short blocks if the head stayed the same other than a deck.
If the head was pressurized and the valves were all closed it may have checked out ok because of the oil flowing in the reverse direction of the pressure check. I am no expert on this subject but it gives you another scenario to look at.
Yes, all pistons have oil pooling on the tops, they're shiny and wet, the one from the passenger side had the most oil on piston tops.
Head was originally done by TTR, so valves, seals, springs, retainers. Second time around I took the whole engine over to BR as I couldn't stand the oil use and the engine's been redone by them, so when I noticed the engine burning about the same amount of oil, the last remaining thing left in the oil path that hasn't been changed was the Turbo.
After changing Turbo's the same amount of consumption continued, and I examined exhaust port and intake piping, there is no visible sign of the Turbo spewing oil.
If it was valve guides, wouldn't that smoke during start up? Car never smokes during idle or start up, and even driving it, it doesn't smoke unless I start boosting it. I'm no expert either, I have to get around to doing that leakdown, but I just want to take the car somewhere so they can figure out wtf is going on, for example, 70mile casual drive yesterday resulted in 1/4qt of oil vanishing.
Old Jul 11, 2013 | 08:48 AM
  #107
bbong's Avatar
Just for logging purpose: 1550 miles travelled, gone through 4qt's of oil and dip-stick shows level being between High and Low mark.
Old Jul 11, 2013 | 09:16 AM
  #108
ExViTermini's Avatar
Take a picture of a spark plug and post it.
Old Jul 11, 2013 | 09:44 AM
  #109
bbong's Avatar
Here are the picture attempts of the piston through the spark plug hole, notice the big shiny pool of oil:
Old Jul 11, 2013 | 10:48 AM
  #110
bbong's Avatar
I'll drive around and take out the same plug after driving, let it sit over night and see if the crude pool shows up again, if it does then it would make it a head issue, guides or seals? But why isn't it smoking at start up with so much oil sitting there? :/
Old Jul 11, 2013 | 12:34 PM
  #111
bbong's Avatar
I just let it idle and reach the operating temperature, then I floored it few times and lots of black smoke came out initially and then it stopped. I then removed the plugs from the same piston and now it looks more proper.
Notice that the pool of oil is gone:
I'll let it sit for a while and see if shows up again.
Old Jul 11, 2013 | 01:09 PM
  #112
bbong's Avatar
Verified, pool of oil is slowly propagating and it looks like it's coming from the intake valves:
Old Jul 11, 2013 | 01:52 PM
  #113
If that was oil sitting there it would smoke it's *** off upon startup. I don't see that much sign of oil on your plugs..
When you changed turbo's were the exhaust ports on the head wet? Have you pulled your downpipe off and looked to see if there was signs of oil there?
Old Jul 11, 2013 | 02:06 PM
  #114
bbong's Avatar
Nope, they were not wet, that's what puzzled me, as in other cars, there was visible oil residue either on the exhaust ports or the exhaust portion of the turbo and there was none.
The DP was removed many times, I'll probably remove it again today as well as the intake mani. and look at the valves steams.
Old Jul 12, 2013 | 06:35 AM
  #115
j255c's Avatar
This is very bizarre.
Old Jul 12, 2013 | 08:26 AM
  #116
TurboTravis's Avatar
TTR was/is(?) either a big hit or a big miss in regards to machine work/engines in general.....
My guess is the head needs work. You've got this far and are obviously determined to fix it, so I would pull the head and send it to a reputable shop. Regardless of where you send it, demand new valve guides/seals/etc....
(I have to mention that because I once spoke with a shop that it was ok to reuse valve stem seals on a 1500HP Modular Ford build)....
Old Jul 12, 2013 | 08:43 AM
  #117
gotpsi?'s Avatar
If the oil pools up.from just sitting it has to be from the valve seals, oil will not creep up past the rings and pool up on top if the piston.
Old Jul 12, 2013 | 11:57 AM
  #118
WRC-LVR's Avatar
/\/\ this is correct. Seals in the head or valve guides are screwed. What i dont understand is that BR had it apart as well. did they or did they not do valve guides. did any one at anytime check valve guide to valve clearance using the old rocking techniques and micrometer. Were the guides just knurled by the first machine shop? That would cause issues down the road
Im thinking the valve stems are on the thin side and the seals are not working properly on them, allowing the oil to seep past on shut down to pool in the cylinders.
My .02c is that you need to have all the guides replaced, have the valve stem clearance checked ( if out of spec, new valves are in order ) new seals ( make sure they are the correct ones for the springs....there are interference issues with running some dual springs and the valve seals ). then get re-tuned. Make sure the catch can system pulls enough vacuum from the valve cover under all conditions of boost to prevent pushing oil down the seals.
And keep monitoring the oil usage rate.
Old Jul 14, 2013 | 12:17 PM
  #119
bbong's Avatar
Engine didn't survive HPDE and spun a rod bearing , going to call Buschurs tomorrow , there was some metal shavings in the head too going to take pics tomorrow as i have no idea where that metal came from.
Old Jul 14, 2013 | 12:50 PM
  #120
TheBoz's Avatar
Wow, I really don't even know what else to say.
