Evo 9 GSR & TTR Built 2.3L Oil Consumption
Old Jul 14, 2013 | 01:26 PM
  #121
ExViTermini's Avatar
You seriously tried to road race an engine that has a severe oil consumption issue? I would be entirely suprised if Buschur does anything for you aside from charging you for a new engine.
Anyway the metal in the head is likely bearing material. It will be in the oil cooler and the turbo as well. Plan on replacing the oil cooler too, else replace the new engine after it's destroyed as well.
Old Jul 14, 2013 | 05:37 PM
  #122
bbong's Avatar
Originally Posted by ExViTermini
You seriously tried to road race an engine that has a severe oil consumption issue? I would be entirely suprised if Buschur does anything foar you aside from charging you for a new engine.
You pay to play.
Old Jul 14, 2013 | 06:57 PM
  #123
This is true, however no need to intentionally cost yourself more money.
Old Jul 15, 2013 | 06:43 AM
  #124
gotpsi?'s Avatar
Guess you don't have to worry about it anymore. But use a different builder next time.
Old Jul 18, 2013 | 12:15 PM
  #125
bbong's Avatar
Since the Motor's relatively new, I'm taking it to Buschurs as they want to inspect it.
Old Jul 19, 2013 | 04:32 AM
  #126
tscompusa's Avatar
hopefully you can find the cause.
Old Jul 19, 2013 | 05:33 AM
  #127
way2qik's Avatar
Originally Posted by bbong
Here are the picture attempts of the piston through the spark plug hole, notice the big shiny pool of oil:
My car would barely run if my plugs looked like that. That plug is fouled w/oil.
Old Jul 19, 2013 | 06:02 AM
  #128
tscompusa's Avatar
ya those plugs look horrible. and that white color means it was running very lean also.
tune was def not lean;
but the car always did seem down on HP.
Old Aug 6, 2013 | 05:32 PM
  #129
bbong's Avatar
Now I'm in need of a good engine builder, preferably within driving distance of 18610 (Blakeslee, PA) any that can be recommended?
Old Aug 6, 2013 | 06:27 PM
  #130
What did David conclude?
Old Aug 6, 2013 | 07:01 PM
  #131
bbong's Avatar
That the engine needs rebuild, spun a rod bearing then mains, valves hit the pistons, one rod shot so needs weight match and line hone the block. Possibly change few valves.
Old Dec 6, 2013 | 08:35 AM
  #132
bbong's Avatar
Got the engine from JAM, dropped it in, now at break-in stage. But car doesn't smoke at all! I just hope that it wont consume oil either
Old Dec 6, 2013 | 10:54 AM
  #133
Evoloved's Avatar
Did the Spun Bearings come from lack of oil, due to the huge leak?
Why did the valve hit the piston?
Old Dec 7, 2013 | 08:35 AM
  #134
bbong's Avatar
... What I heard is that I could have been burning oil in cylinders, lowering octane level and causing it to knock, be lean and from there you can imagine what the poor bearings must have endured.
Though, I wouldn't mind David to chime in and say what happened after his inspection of the engine, but that's all I know.
Old Dec 7, 2013 | 09:14 PM
  #135
TeachersEvo's Avatar
Well, it is possible (maybe not on these engines, however...) that when the bearing material destroys itself the rod will pull itself off the crank far enough to make contact at TDC... I had a 12.5:1 Honda engine that while it did not bend valves, clearly stamped the arrow on the piston (for direction on installation...) into the combustion chamber
