Evo 8 with MAP EF2.5
Old Jan 16, 2013 | 12:53 PM
  #31
mean4g63's Avatar
what thrust bearings come in the EF 2.5 (as the EF 2 doesn't actually have the heavy duty versions)?
Old Jan 16, 2013 | 12:56 PM
  #32
ChrisCarey's Avatar
The thrust bearings are the same as the EF2, however they are still an upgrade over OEM thrust bearings based on the dual oiling feature.
Old Jan 17, 2013 | 07:33 AM
  #33
evotuner04's Avatar
15 Year MemberLikedLoved
Originally Posted by DisgustipatedM3
And that's where I come in. I'll do the testing for MAP and show how well this turbo does on your average Evo 8/9 on both 91 and E85.
Mine should be done shortly, possibly even today
Ill get it in asap and hit the dyno
Old Jan 17, 2013 | 07:50 AM
  #34
DisgustipatedM3's Avatar
What's your altitude there? And are you using a Dynojet/Mustang? We should use the same correction factor and see how our numbers correlate once we're done. That way we have even more concrete data for gains.
Old Jan 17, 2013 | 09:19 AM
  #35
maperformance's Avatar
I am looking forward to comparing the data...and thanks for the kind words earlier...we are all car guys here and always looking for way to tweak things to make more power!
Old Jan 17, 2013 | 10:57 AM
  #36
evotuner04's Avatar
Here in Mankato MN its 794ft. Then about an hour north of here where I'll be getting tuned at its 971ft.
I'll be using RS Motors Mustang Dyno and at some point I'm sure I'll hit MAP's dyno. Cant wait just heard turbo is done, I might be headed for a little drive to go get it
Old Jan 17, 2013 | 09:17 PM
  #37
evotuner04's Avatar
Here she is
Compared to the EF3 anti surge:
Old Jan 18, 2013 | 10:08 AM
  #38
Looks awesome! What is the WGA preloaded to?
Old Jan 18, 2013 | 11:41 AM
  #39
Levar's Avatar
Veteran: Army
Truly looks like a beast. I like it.
Old Jan 18, 2013 | 01:38 PM
  #40
louiesevox's Avatar
Sub'd for dyno results
Old Jan 18, 2013 | 04:24 PM
  #41
evotuner04's Avatar
you know i never did ask but im guessing 23psi. Maybe MAP could chime in on this one
Old Jan 21, 2013 | 09:37 AM
  #42
ALL MAP turbos come with a pre-installed 18PSI spring...we ALSO supply an additional 5 PSI spring that is to be installed in addition to the 18PSI spring should you need it.
Any more questions? Feel free to ask!
Nate
Old Jan 24, 2013 | 07:18 PM
  #43
evotuner04's Avatar
just wanted to bump this thread, tune next week I'm thinking. A little too cold here in MN to have the dyno doors open
Old Jan 25, 2013 | 06:51 AM
  #44
SuperchargedGTZ's Avatar
any reason why you didnt go with the anti-surge?
Old Jan 25, 2013 | 08:04 AM
  #45
evotuner04's Avatar
i wanted it to spool as quick as possible. kracka did testing on the evo x turbo and said you really dont need the anti surge for it and figured i might as well try it. a lot of locals who are running the ef2 have zero surge issues so i'm not too concerned.
