GSC 0-tick lifters different length?
Since you have concerns... turn that motor over by hand and make sure they dont sling a rocker.. I had that happen and that should also put any worries to rest and mitigate risk and you wondering what the hell happened on my new build. Just a thought. GL.
Thanks for the advice but I made sure I did that. After putting the cams in and timing the engine I rotated it about 15 times, periodically checking the lifters/rockers and making sure I didn't hear any crazy sounds. everything sounded great and turned smoothly.
Did they just have you bleed them?
I followed the normal procedure on bleeding them and once installed in the head, the valves never close all the way. 0 compression.
2.4L +1mm Valves on S3s, no piston to valve issues as the pistons have huge relief cuts. Never had an issue on stock lifters so I put them back in, just trying to quiet it all down, and the stocks have like 130k on them lol.
Hopefully I don't run into those problems. I'll have to double check when I get back, i'm deployed right now and having the car sit for 5 more months is making me slightly nervous. lol I kept my stock lifters though they only had 65k
I just installed a set and made a few notes - two thumbs up:
https://www.evolutionm.net/forums/ev...l#post10754364
Howulikemyevo
40
Sep 29, 2021 04:39 PM
Ted B
15
Dec 24, 2013 08:34 PM
