Removing TPS sensor question
Old Feb 22, 2013 | 02:53 PM
EvoIXPilot's Avatar
Following the DIY on removing Thottle body and on the part of removing tps sensor, it said its just easier breaking the metal clip as it is just a clamp. So if I do this, when I reinstall the TPS sensor with a one broken clamp, would it stay on??
Old Feb 23, 2013 | 12:27 PM
GGevo921's Avatar
No need to break it. Just unbolt the tps. Which is two 7mm bolts. A 1/4 inch ratchet and a 7mm will work. Unbolt. Then use a pick tool to pull the clip. Once removed. Put the connector slightly over the sensor to reinstall the clip. That way it's ready to go once and you can just plug it on when you reinstall. Also don't fully tighten sensor back down till it reads 13.33% on evoscan. Hth!
kamote2000
Mar 8, 2017 12:30 AM
turboedv6
Aug 29, 2015 06:37 AM
Dvolution
Jan 14, 2014 03:29 PM
awdordie
Aug 29, 2013 05:43 AM
widge
Nov 3, 2012 03:54 AM
