Transmission questions...
Old Apr 4, 2013 | 06:18 AM
MrJuls's Avatar
Worst of all is when i got the car there was a screenshot of an invoice in the glove box of a transmission replacement.Not sure on what mileage it was replaced...
Old Apr 4, 2013 | 08:10 PM
05EVORonmc's Avatar
Just an update, got a new stage 2 tranny from shepard transmission. Great guys, were very helpful, helped me decide to go 5 speed. I recommend them for any transmission needs. Super customer service and quick shipping. Hopefully the Evo will be back on the road after this weekend, this down time has allowed me to detail and install all my intercooler piping as well.
Old Apr 4, 2013 | 08:14 PM
05EVORonmc's Avatar
yikes... sounds like my situation Hopefully it will last for you, if not thankfully there are many options for us to support more power.
Old Apr 11, 2013 | 05:04 PM
05EVORonmc's Avatar
I already bought the transmission still not installed, but I need help, this doesnt sound like a transmission anymore....
Old Apr 11, 2013 | 10:36 PM
MrJuls's Avatar
Hope so...I'll see how the 4th gear is after the shifter bushings install.Then it's a new clutch...
Old Apr 11, 2013 | 11:32 PM
fireroasted's Avatar
I already bought the transmission still not installed, but I need help, this doesnt sound like a transmission anymore.... http://youtu.be/hPiz3-f7cTs
Yikes. That sounds seemed very external, and didn't seem to be effected by RPM, just motion. Its hard to tell, but drive shaft, axle joint, or even brocken brake pad jumped to my mind. Did it actually jolt when the sound came impeding your progress, like you hit a bump?
@MrJuls - I track my 6speed and always have. Its actually what it was intended for. In stock form the ratios are perfect for track duty. I prefer the way it shifts, but its not for drag racers. Its too short. I have a step built 6 speed, and i don't think the stock box is weak, even for moderate power. Based on everything I read, and my own tests, heat on track goes crazy, because that thing doesn't hold enough oil. I killed my 4 gear syncro, from what was essentially an endurance track day, where I didn't let the car cool down, and it was 110 degrees at Spring Mountian outside vegas. I now have a self made cooler, and it works very well. That would be the modification I suggest to anyone wanting to run a 6 speed, actually any trans on track, likely needs better cooling. Its trans insurance.
I got the final drive, and I regret that one. i don't make enough torque/power to make up for the loss in low gear low RPM grunt. MPG cruising got a huge bump though, and I do DD the evo too. I still preferred the stock ratios though. Maybe if i could make more grunt down low I might change my mind.
Old Apr 14, 2013 | 11:29 PM
MrJuls's Avatar
Thanks for the reply.I only do open track days nothing serious,and i'm only allowed to go about 4 laps because my water for the water/meth only lasts that long.So i think the car cools down enough when it's our class' turn to go again.
I'm going to replace the clutch when money allows,because i need a new one.And i'm waiting for my Torque solution shifter bushings as well.
MagicManRed
596
Dec 9, 2020 07:59 AM
acid7711
Sep 26, 2016 08:06 AM
brunz44
Jun 26, 2012 01:33 PM
boy36
Nov 4, 2007 03:46 AM
Kami
Mar 18, 2007 10:03 AM
