Evo 7 GTA Turbo/Cams Help.
Old Apr 11, 2013 | 12:34 PM
  #31
ahlim13's Avatar
Originally Posted by Stimmed
Ah nice thats promissing! hope my tuner can get similar results Im going with the DBB FP Green so should be fun .
Hope to hear ur result sooner..
i decided to take that hks gt2 on next month..
Old Apr 11, 2013 | 11:36 PM
  #32
Ang Wen Yan's Avatar
Originally Posted by ahlim13
First dyno graphc spec is
stock evo 7gta turbo
aftermarket extractor and intake
greddy profec b 2
Apexi safc
Engine is fully stock, included intercooler. Just some samco hose.
(When i just bought this used car , previous owner didn't tune. He just adjust hi/low boost himself and proper AF tuned)
http://img600.imageshack.us/img600/8779/img1096h.jpg
Second picture is
ECUtek reflash tuned
Apexi SAFC dissembled and sold (tuner said i wont need it after tuned, he is rite, i dunno how to use it anyway)
Replaced fuel pump with walbro.
others remain same.
http://img542.imageshack.us/img542/2969/img1097m.jpg
Third picture is
Evo8mr turbo - low boost n hi boost with ECUtek retuned.
others mod remain same as above.
http://img703.imageshack.us/img703/6692/img1098h.jpg
Internal actuator right??
Local tend to run external wastegate and make the turbo effectively single scroll
Same nick on ZTH??
For some reason ZTH people very not keen to post up dyno sheet
Your result is not bad for GT-A
330whp GT-A going to be
Perhaps you can do 350whp with say a set of GSC S1?
Another turbo alternative would be FP 71HTA
Same result as HKS GT II but cheaper
Old Apr 12, 2013 | 12:39 AM
  #33
ahlim13's Avatar
Same nick on ZTH??
yes internal actuator..
yep. same nick as zth forum. I don't want post dyno sheet there.. Many ppl there are "less" educated and they just flame me for bs story
prefer this kind of forum with mostly polite ppl around.
Old Apr 12, 2013 | 08:08 AM
  #34
If you know,i kena gangbang by them before
EVOFans on ZTH
Malaysia forum
Old Jun 1, 2013 | 06:49 AM
  #35
ahlim13's Avatar
hey guys.. any update?
im really interest to know how is ur mod n result
Old Jun 15, 2013 | 01:08 AM
  #36
Stimmed's Avatar
Hey Ahlim13,
Sorry been busy I got the car back about a month ago.
Current mods:
FP Green DBB
Tomei Dump
HKS Pod Filter
Walbro 255
Xforce Exhaust
MBC
... Think thats it.
Tuned on 98 Preimum in Australia.
Came in at 191awkw. Not quite what I wanted but happy with it none the less auto box really saps the power tuners said if it was manual would be at about 220 awkw.
Im putting it in again in 2 weeks for the following:
ETS Intercooler Upper and Lower pipes (going Matte Black)
GSC S1 Cams (not 100% sure ill go cams yet but I am leaning towards getting them.)
ID 1000cc Injectors
E85 Tune (found out there was actually a station 10 minutes away!)
Stage 2 Shift kit.
So I will put in another update when that's all done really not sure how much power it will make but should be a nice change
Old Jun 16, 2013 | 03:52 AM
  #37
ahlim13's Avatar
Hey Ahlim13,
Current mods:
FP Green DBB
Tomei Dump
HKS Pod Filter
Walbro 255
Xforce Exhaust
MBC
... Think thats it.
ID 1000cc Injectors
Stage 2 Shift kit.
thx for sharing. Can u share the dyno graph of yours? i wanna see torque n hp curve at earlier rpm.. peak power might be not ur expected.. but may be entire low n mid power gained?
Update me if any new things too.. thx ^^
I haven't buy the HKS gt2 7460r yet.. but last few week ago i just overhauled and upgraded my gearbox.
i broke one half year ago. Planetary gear damaged.. teeth chewed. Replaced an used unit which already 150k km.
Recently I was told every evo7 gta gearbox wave spring is too fragile.. it will break at high mileage or aggressive driving style..
So i upgraded it and I'm quite believe what this workshop telling me. He is specialist for airtrek, evo..
a thing i must do before.. few of his clients 350whp running many years are still good.
He show me the airtrek and evo7gta is using same gearbox and inside some of their parts are a lot stronger. Mean Mitsubishi revised this type of gearbox at 2003 onward.. but 7 GTA was obsolete and didn't bother to recall or change. Sumore 7 GTA only selling in japan.. that's why no much info about this model.
Now i feel faster up shifting.. acceleration improved. Almost work like a DSG in normal mode.. but down shift is still far from those DSG or SST. (I did tried evo x and golf gti before)
Old Jun 16, 2013 | 05:41 PM
  #38
Tas evo7,04/636's Avatar
Hi...my name is David from Australia with evo GT-a with quite a few mild upgrade's pulling 263 on 98 RON, MY GEARBOX SEEM'S TO BE STILL RUNNING strong and fine but I am only just gone over 102.000 kms....I was wondering how much it cost for the gearbox upgrade u just mentioned? remember mine is fine still so I am not sure but I imagine your's included extra fix it cost's as it was stuffed, Do you know how much about just for upgrade you mentioned WAVE SPRING and anything else that required from good condition gearbox? Thanks a lot....David(TASMANIA,Aust)
Old Jun 16, 2013 | 05:54 PM
  #39
Also I was thinking about turbo upgrade but this thread has been handy with info for changing my thinking on it.
The dyno sheets of tuned ECUtec remap gt-a turbo were high 259...like I think even by memory 259.94 yet with the 08mr turbo it only increase to 261.08 (that's like nothing) and sure it to power abit quicker like mr turbo reached 238 KW at was 4000 rpm spot on to the end of straight power gain line but the GT-a with normal turbo wasn't much slower at all even there and reached 235 KW at about RPM 4,350 rpm, so to conclude it is only 3 KW more 350 rpm sooner.
That dyno just totally made my mind u to keep my car as it is.... especially with them mean't to be specially designed to suit the car and give extra benefits elsewhere.(9T turbo over the 10.5 that is).
Old Jun 16, 2013 | 09:35 PM
  #40
sparky's Avatar
Internal actuator right??....Local(s) tend to run external wastegate and make the turbo effectively single scroll.....
Would you care to elaborate, please? You have me wondering about the single scroll modification Also, tell us where they are sourcing the external gate from. Any pics?
Old Jun 17, 2013 | 01:49 AM
  #41
ahlim13's Avatar
He charged me RM 4500 (u can convert malaysia ringgit to ur currency). Torque converter inside all the friction plate n pump upgraded too.. free reprogram gear timing after 500km run.. now i only 250km.. rarely drive recently. Warranty 6 months unlimited mileage.. but warranty doesnt cover planetary gear broken.
There is one transmission workshop quote me rm2500.. but i dont have confident to let him do.. prefer go forthe guy driving same car and doing evo repair job everyday.
Actually it is WHP .. i will be glad if its on kw unit.. XD
I was told by tuner that the turbo will be gain a lot more if i replace other cam such as gsc1 or stock manual evo cam. Auto cam lost top end power..
he showed me one e7gta 8mr turbo with 8mr cam 290whp.
Btw i shd dyno it again soon.. not only i feel changing gear better since upgraded gearbox.. i feel like i gained some torque too... quite feeling like manual car pushing me into seat.. i'm expecting few kg torque increase.
ya.. 1 more thing i repaired. I complained my car having knock back long shaft noise everytime i immediately let off pedal at low speed (under 30 kmh) while accelerate..
Found out it's the centre transfer case.. inside teeth chewed.. almost flat.. i have video can show u guys auto one is different.. the manual one is a lot stronger material which wont break like this.. the workshop converted mine to manual version with still using my own case. He told me quite common for airtrek too.. especially the car getting old or improper launching.. he repaired a lot of this same problem.
Now i can deaccelerate like new car.. especially the torque kick in and let off gas.. no cabin noise kicking.. quite happy..
Old Jun 17, 2013 | 02:29 AM
  #42
Stimmed's Avatar
Sorry I dont have the Dyno Sheet any more lost it somewhere!. Ill make sure I get the next one to upload it for you.
Good to hear about the cams waking the turbo up a bit more think ill have to do that for sure .
Have to ask about the Wave Spring. Im getting as stage 2 shift kit for it im told it quickens up the gear changes makes it more snappy it might include that will have to see.
Old Jun 17, 2013 | 03:33 AM
  #43
ahlim13's Avatar
this is the thing i talked about..
Old Jun 17, 2013 | 06:36 AM
  #44
sparky's Avatar
..... the power at earlier rpm range is a lot better.
dun forget ori gta turbo is 9.0T.. my 8mr is 10.5.....I guess material turbo is different. I tried weight the GTA turbo feel bit heavier than 8mr titanium turbo. 8mr seems lighter.....somebody offer me his HKS gt2 ballbearing turbo.. Now i'm planning upgrade again...
Contrary to what you are experiencing, the 7 GTA turbo should spool significantly faster than the 8 MR turbo all else remaining equal. The 9.0cm turbine housing has a much tighter(smaller) A/R. Also, unless I am mistaken, the VIII MR turbo did not have the Titanium-Aluminide turbine wheel. So, both wheels are Inconel material and thus should weigh substantially the same.
Old Oct 18, 2013 | 02:21 PM
  #45
yungchian.chen's Avatar
Where do you repair the evo auto gear box at malaysia?
Nawshad
Sep 28, 2016 01:46 PM
Nyaim
Jul 15, 2014 08:59 AM
jackieL
Jul 15, 2013 10:10 AM
Spare-Flair
Aug 18, 2003 01:06 PM
bimmerbong330ci
May 14, 2002 05:44 PM
