Fullblown 70mm TB - TPS adjustment
Old Apr 2, 2013 | 02:31 PM
Graphic's Avatar
I have recently added a 70mm Fullblown TB. When I set WOT to read 100%, idle reads 23% ish at full sweep. If I set idle to 13.3% wot is maxed out at 92-95% on a full sweep as well. If I hook my tps up to my stock TB i have full sweep from 13.3% to 100%.
Has anyone tuned a stock ECU evo with the 70mm full blown? What is the resolution to this issue? I haven't started my car yet but I'd like to know what I need to do? I'm thinking there are settings that need to be changed in ECUFlash? Any help would be appreciated!
Old Apr 2, 2013 | 04:38 PM
Graphic's Avatar
I know somebody knows this answer.... I need to know this so I can start my car and get it tuned.
Old Apr 2, 2013 | 05:17 PM
211Ratsbud's Avatar
I did don't worry about wot reading just get your target idle in check and your idle tps at below 16%
Old Apr 2, 2013 | 05:18 PM
Graphic's Avatar
Sweet! Thanks man. So my tuner will just tune out the fact it states 9X.xx % WOT? I can get 13.333 idle np.
Old Apr 2, 2013 | 05:20 PM
211Ratsbud's Avatar
Yea that's it. I used to read 96 at wot.
Old Apr 2, 2013 | 11:44 PM
Graphic's Avatar
Cool thanks again man!!
Old Apr 3, 2013 | 01:10 PM
browningderek's Avatar
Idle should read 14-17%... get that adjusted and wot tps reading doesn't matter. 98%, 100%, same thing.
Old Apr 3, 2013 | 01:20 PM
badev0's Avatar
Mine is 12% at idle, 92-94% at WOT. As long as you're in the 90's at WOT you're fine.
Mine has no issues and drives like stock. I also run the full blown 70mm.
Old Apr 3, 2013 | 01:27 PM
mdsevo06's Avatar
Idle should always read 13.333, stock or Full Blown.
FullBlown
88
Dec 30, 2018 04:06 PM
Sideck
Apr 1, 2018 05:52 PM
wagonwes
Aug 10, 2016 08:16 PM
neonglh
Apr 16, 2015 06:18 AM
yellowevo82
Aug 30, 2009 02:31 PM
