Low Compression
Old Apr 12, 2013 | 12:41 PM
element26's Avatar
Low Compression
So I did a compression check on the car today. I got 1-120,2-90,3-60,4-120. Wtf.... Car seems to run fine.
Old Apr 12, 2013 | 12:50 PM
escodotcarter's Avatar
was it a cold test or hot test? did you put some oil in the cylinders that were low and retest?
Old Apr 12, 2013 | 01:39 PM
element26's Avatar
It was a cold test. And when I put oil in it, it went up but not that much
Old Apr 12, 2013 | 01:42 PM
Ev0ikon's Avatar
What gave you the nudge to have compression tested?
Old Apr 12, 2013 | 01:44 PM
element26's Avatar
When it would start it would sound like it was only running on a couple cylinders until it warmed up then it would sound normal. So I just decided to check for the hell of it
Old Apr 16, 2013 | 12:17 PM
Ev0ikon's Avatar
If repeated tests still gave you the numbers above, you have 2 choices:
-Run it as it until it can't drive any more.
or
-Take it apart and hope for a cheap fix (like a new set of rings or a head gasket).
Old Apr 17, 2013 | 09:47 AM
EvocentriK's Avatar
2 low comp readings in adjacent cylinders not much affected by adding oil - could be headgasket. Has it had a hard life? Why not do a hot test also?
Old Apr 17, 2013 | 09:53 AM
detroit pistins's Avatar
I ran into something similiar recently and it ended up being a broken valve spring that prevented the valves from sealing. But it was only 1 cylinder that was low. maybe worth taking out ur valve cover first before removing the head.
https://www.evolutionm.net/forums/ev...sd-93-oct.html
Old Apr 17, 2013 | 08:24 PM
CDrinkH2O's Avatar
Off with its head! (Can be done in a couple of hours)
Old Apr 17, 2013 | 08:35 PM
Force-Fed Performance's Avatar
do a leak down also. but it could be a couple different things. You are close to us if you would like give us a call during regular business hours and we can walk you through some things to check
dtenev2
15
Nov 4, 2017 12:11 AM
12WWGSR91
Nov 8, 2016 10:38 AM
nukleus
18
Jan 8, 2016 04:05 PM
Brandisher
Apr 24, 2015 07:39 PM
ym827543327
Apr 6, 2015 07:56 PM
