How do you test the boost control solenoid?
Old Apr 27, 2013 | 05:34 AM
MrJuls's Avatar
I've got a Perrin 3-Port EBCS.The car is boosting way more than it should and i'm picking up a lot of knock.How do you test the EBCS?
Just put a multimeter on it and see if there's current running through it?
Or could it be my turbo wastegate that's gone bad? If i pull on the actuator it still opens,so i doubt it's that.
Old Apr 27, 2013 | 10:24 AM
browningderek's Avatar
Bottom right on evoscan. Actuators. Click boost solenoid and the solenoid should click when evoscan shows on.
Old Apr 27, 2013 | 01:48 PM
MrJuls's Avatar
Thanks,will find out from my tuner.But i guess i could test the wiring myself also because i would have to drive 59km to get to my tuner.
Old Apr 28, 2013 | 10:55 PM
MrJuls's Avatar
Tested it with a multimeter.Getting 1.1 ohms.Is this normal? Car was switched off.
It seems a little low...
Old Apr 29, 2013 | 09:45 PM
MrJuls's Avatar
Anyone? Has anyone ever tested this?
Old Aug 16, 2013 | 12:50 PM
aggieEVO's Avatar
Did you ever get this? I just installed a stock BCS and boost lines (new with pills). I'm only able to hit 15psi. Wondering if my stock solenoid is bad.
Old Aug 16, 2013 | 01:19 PM
Raptord's Avatar
Bit late and I assume OP's figured it out by now, but maybe this'll help others in the future:
When you change your stock BCS to an aftermarket BCS (grimmspeed, perrin, whatever), you MUST have the boost retuned because the new BCS can reach much higher boost than the stock one. On the stock system the WGDC tables are nearly maxed out, whereas you'll want approx. half of those values on an aftermarket solenoid.
Old Aug 18, 2013 | 11:48 PM
MrJuls's Avatar
Hi,yes I ended up disconnecting it and ran it on wastegate pressure...but it's fine,still working good.I just think my soldering skills need some work...
Ferp
Apr 19, 2017 07:58 PM
Mag00n
Sep 14, 2012 05:04 AM
andrewr
Mar 28, 2011 02:01 PM
bnr34rb26dett
13
Dec 11, 2010 09:40 AM
Methodical4u
11
Sep 21, 2010 09:50 PM
