What fuel pump can I use
What fuel pump can I use on evo8 going for 500+ don't have money for a double pumper so please give me advise thanks as in fuel system wanting to go e85 in the near future
Modded 255s have been said to make it. Never personally seen it... But its what they say. A 450lph walbro will happily do it... Its been my experience then tend to tear the pump grommet. 3 times on mine and once each on 3 local car but it could be our fuel...
I modded my fuel pump housing to except a 450 like double pumper with a single pump... If that makes any sense...
To avoid installing a double pumper upgrade your fuel line to something like a -6AN or -8AN. It will put less stress on the fuel pump by lowering fuel pressure at higher RPM and will in turn supply more fuel.
I have reciepts and pics this evening if interested.
$300
Much cheaper than the double pumper and it will get you 500hp easily.
The previous owner of my car said that they had pump issues with a Walboro 400 making 550whp on E85.From the research I did I found that 500 or so is the max for that pump on E85. The Walboro 416 or double paper is your best option IMO.
I am going to go - 6an line and 2 255 Walbros to be safe. I know it s a bit excessive for 500+whp but I don't want to have any issues.
Check out the Walboro 400/416 comparison thread.
Posted from Evolutionm.net App for Android
I have a walbro 450 (Made for e85) set up with your name on it. Its already in the modded stock housing. All you have to do is bolt it up. The pump is next to new. Only purchased it two weeks ago.
$300
$300
EvO-LOui
14
Jul 17, 2013 04:49 PM
