Evo 9 turbo install
Old Jul 6, 2013 | 12:33 PM
sergio916's Avatar
Evo 9 turbo install
i just put in a evo 9 turbo with turbosmart wastgate on my evo8 everything installed right.. but when I started it up left it running for a while and took around for a spin the car has no turbo power the bov doesn't sound like its working.. any ideas what could be wrong with it.. maybe a tune or reflash..vacuum leak on turbo outlet pipe or wastegate.. I did reuse the old evo 8 coolant and oil lines for it to fit my evo 8.. any help thanks...
Old Jul 6, 2013 | 01:12 PM
gsrboi80's Avatar
Turbosmart wastegate actuator you mean??
Did you perform a proper boost leak test once install was completed?
Old Jul 8, 2013 | 12:15 AM
MrJuls's Avatar
And a retune...
Old Jul 8, 2013 | 12:49 AM
deylag's Avatar
Definitely sounds like there is a boost leak. Also could be that the waste-gate actuator is opening early. I would check the adjustment.
TURBO_S2K
12
May 1, 2016 05:54 PM
Charlie-Y
28
Apr 23, 2014 07:00 PM
yellowevo82
Mar 9, 2014 11:28 AM
JDM EVO PANAMA
Oct 24, 2010 06:05 PM
chaz517
96
Dec 24, 2006 07:43 PM
