harmonic damper
Old Jul 17, 2013 | 01:09 AM
tupac1's Avatar
harmonic damper
Hi I currently have ATI super damper on the car, been on there for about 50000ks. The oil seal is slowly leaking you can see it in the area around and under the damper.
My mechanic thinks its useless once he takes it off to replace the seal.
He thinks he might even have to cut it in half to get off as its on there tight what with vibrations from crank how long its been on there etc.
Whats should I replace it with? What are the big powered guys using?
Cheers
Old Jul 17, 2013 | 03:13 AM
EvoDan2004's Avatar
Either your description is not correct or your mechanic should not be working on anyone's car. There should be no reason he can not get it off.
You must run some kind of damper pulley. Stock is ideal but lots of people use fluidyine or ATI seem to be the choice most go with.
Old Jul 17, 2013 | 10:12 AM
tupac1's Avatar
Yeh ack with my description my mechanic is Asian and is sometimes hard to understand
From what I gather he had to cut one off another circuit car not sure why or how that's possible without damaging the parts around it.
Old Jul 17, 2013 | 04:07 PM
kpr's Avatar
kpr
I've never seen one on a Mitsubishi that tight. They are not pressed on
Old Jul 18, 2013 | 07:12 AM
Teal2nnr's Avatar
I run a Fluidyine...it’s great. I'm not sure why your "mechanic" would say its useless as it clearly has a purpose and works very well....at least it does for me. I have the balance shafts removed in my car, and it doesn't vibrate or shake at all (compared to my buddies car which has noticeable vibration and no dampener)
Old Jul 19, 2013 | 04:43 AM
tupac1's Avatar
Yes same here don't have balance shaft either so it doesn't vibrate that much I don't think... well as much as a car with solid engine and gearbox mount
So you reckon I need new one once I replace seals?
Old Jul 19, 2013 | 09:58 AM
Teal2nnr's Avatar
Not necessarily. Depending on age it might be find. Its just some sort of fluid inside the pulley, so as long as it hasn't degraded you should be fine.
Old Jul 19, 2013 | 11:11 AM
Ev0ikon's Avatar
ATI needs to be rebuit after a time. Fluidampr ones for the Evo don't need a rebuild.
It is secured by 4 bolts and don't need anything but hand tools to remove.
Old Jul 19, 2013 | 11:59 AM
AlmostHadMe's Avatar
Re
Old Jul 19, 2013 | 12:01 PM
Fix your seal leak, and I'd recommend replacing it with a unit from fluidampr.
Old Jul 21, 2013 | 06:18 PM
03whitegsr's Avatar
The ATI comes with a different crank pulley as part of the damper and it is pressed on.
The type of vibrations damped aren't the type you really feel. They damp torsional vibration, not the vibration associated with the balance shafts. The balance shafts counter the natural vibration of an I4 that can't be eliminated without the balance shafts.
blockade35
14
Oct 19, 2013 01:59 PM
reddragun3
Evo X How Tos / Installations
May 6, 2011 09:26 AM
thientran
Jun 12, 2009 08:46 AM
GruppoB
13
Nov 10, 2007 04:35 PM
rich
Apr 17, 2006 04:41 PM
